Fresh air intake rule help
Started by Camaro2191, May 04, 2018, 04:59:14 AM
Camaro2191
I'm hoping someone can help.  I'm doing the final prep on my car for Arkansas in June.
In rereading the rule book i noted - "All enclosed driver compartments shall be equipped with a forward-pointing fresh air intake..."
I've read a few posts on here about the topic but it still isn't clear to me.  I have a 1989 Camaro that will be running in GC.  The floor is sheet metal but the rest of the body is largely factory.   As noted in a few other posts, I can't easily put a naca duct in the factory side windows.  Does that leave me with running some sort of fireproof hose from the nose of the car into the interior.  I'm not trying to overthink this, I just don't want to have a problem in tech.  I've looked at a ton of cars at bville and Ohio and don't recall a pitot tube like setup in any of them.
Thanks,  Lane.
1989 Camaro - URGENTLY - B/GC and C/GC
Arkansas Mile and Bonneville
No records yet...but I am trying
RichFox
On my Vega, I put a small scoop on the roof just forward of the driver.
Captthundarr
Our 91 camaro has 2" flex exhaust tubing running from behind the left front turn signal to a hole in the fire wall just above the steering column.
