Exhaust System and course surface
Started by ronnieroadster, June 28, 2018, 01:21:08 PM
ronnieroadster
Reading the rule 3.P Exhaust System
    Its written the exhaust is directed away from the driver,fuel tanks,tires and course. So im wondering if the exhaust pipes which are clear of the driver and fuel tank and tires exiting level to the course surface facing on A rearward angle about 2 inches above the surface would that be considered clear of the coarse surface?
      Ronnieroadster
level to course, mean parallel to surface?   if so I think it is not a problem
ronnieroadster
Quote from: SPARKY on June 28, 2018, 01:39:22 PM
Yes parallel to surface Thanks for the info Sparky  :cheers:
