EFI Injector testing fluid,,
Started by stay`tee, July 10, 2018, 04:41:31 AM
stay`tee
For Methanol fuel, what test fluid would you/do you recomend using ??
Speed Limit 1000
What are you testing to discover?
stay`tee
#3
Uniformity/Sprayability, so I figger something with properties similar to Methanol without the worrie of combustion,,
ie, something with a SG of .792
BVCBR
Mineral spirits will probably be your most affordable solution. The viscosity will be a little off, but you can get a few different specific gravity weights if you look for it. Methanol looks to have a specific gravity around 0.78. The Klean Strip Odorless Mineral Spirits from Home Depot has a specific gravity of 0.78. You can usually find the MSDS sheets from the manufacturer on-line and that will give you a lot of the properties that you can compare with the type of fuel you want to run. Here is a link for the Klean Strip stuff http://www.kleanstrip.com/uploads/documents/GKSP94006_SDS-GL251.pdf
N-Heptane is a fluid that has become the "standard" for injector test stands, but is kinda pricey. Last I looked it was a $100.00+ per liter.
I have used mineral spirits a lot. Just be sure to have your area well ventilated and wear some safety equipment, it really burns when it gets in your eyes and will make you smell funny for a day or so when a line comes off and hoses you down.
JW
970B 1000cc P-P
976B 1000cc P-P
977B 1000cc M-G/F
JW;
I think "kinematic viscosity" is a more important criterion than specific gravity.
stay`tee
[/quote]
What you talkin'bout Willis  :-) ,Can you please explain why Sir, ??
Quote from: stay`tee on July 14, 2018, 03:42:00 AM
[/quote]
Specific gravity isn't what is important in this case- it is only a measure of density. Two fluids can have similar specific gravity but one can pour like water and the other like Karo syrup.
The term "Viscosity" is pretty well understood since we all use an oil of some viscosity number in our engines, etc. "Kinematic" viscosity is the apparent thickness (resistance to flow) of a fluid when it is flowing fast through a small hose, orifice, fuel injector, etc. Viscosity of many fluids changes as the flow rate increases.
An extreme example of this is a "Non-Newtonian" fluid. Drop a marble into a pan of it and it hits the surface and sinks to the bottom as one would expect. However, if it hits the surface at high speed, the fluid acts like concrete.
These questions may be on the Final Exam.   :-D
kiwi belly tank
Blinker fluid. :-D
Running alky I test them with alky but flush them with gas.
Speed Limit 1000
Quote from: Speed Limit 1000 on July 14, 2018, 06:42:58 PM
Quote from: manta22 on July 13, 2018, 06:46:04 PM
JW;
https://www.engineeringtoolbox.com/dynamic-absolute-kinematic-viscosity-d_412.html
Johnboy :cheers:
Touche, Johnboy. I should have said "dynamic" instead of "kinematic" viscosity.
That viscosity chart confirmed my recollection from high school Chemistry- that glass is a "super-cooled liquid" not really a solid.
stay`tee
"Thankyou" Neil and Johnboy,, some study for me too do  :-)
stay`tee
#12
So your saying too do the various tests with Alky, but then flush the tester/cleaner system with a non corrosive fluid ??
Quote from: stay`tee on July 15, 2018, 03:32:23 AM
EXACTLY!!!    :cheers: :cheers: :cheers:
stay`tee
Appears as tho I will use the real thing, that is Methanol  8-),, Thankyou gentleman  :-)
