Body class AIR????
Started by GH, July 15, 2018, 12:11:17 PM
GH
I was looking in the pre-entry list and ran across this body class. What is it?
desotoman
It stands for American Iron Roadster. A Gas/Fuel roadster powered by an American gas powered iron production car or light truck motor made prior to 1973, with only one engine class which is a C engine. 306"-372". And some other stuff but that is the basics.
Hope this helps,
RichFox
Iron OEM heads which may be ported and such. Kind of an econo roadster class.
Quote from: RichFox on July 15, 2018, 02:44:45 PM
Econo.... You spend $40000 or so if you can.....
RichFox
Different people have different spending habits.
Ron Gibson
Yeh, some spend $100,000 on an econo class. :-D :-D
Ron
jimmy six
The class should have never allowed Chevrolet V8's or Chrysler Hemi's. The thought was good...execution was poor. The plan was for older other engines. Buick, Olds, Studebaker, Packard, Merc, Lincoln, etc....never going to happen.
Happy Pappy
Would the 351 Cleveland fall into the AIR plan?
Chris
Chris Campbell
2017 #203 G/GR El mirage record 150.771
2020 #62 C/AIR El Mirage record 180.828
6/21 #62 C/AIR El Mirage record 185.488
9/21 #62 C/AIR El Mirage record 194.450
dw230
JD,
Some engines lend themselves to rules restrictions better than others. There are still 10s of 1000s of roadsters "out there" that have yet to surface.
Dynoroom
Skip Pipes
351 Cleveland with a date code of 1969 through 1972 are allowed. No trick one-offs. The burden of proof is on you so if your not used to DW scrutiny than play it safe. Of course it only matters in impound.
I like the class but side with JD & DW, you got to really want to prove something to try this in its current form.
Skip Pipes
Skip's Garage
The class never made a dent in what it supposedly was created for.  Outmoded engines can run in any Roadster, Coupe, Lakester, and Streamliner displacement class they want.  The older cars are usually outmoded in areas besides their engines.  Usually their owners (and/or drivers) are getting ancient, too.
Thinking it's a low-buck entry class is not quite the truth, either, when you're running against Mariani, Davidson and Stringfellow.
jimmy six
RichFox
Had the rules makers required the engines to be single rocker shaft engines only, the class may have evolved as imagined. As it is it seems pointless to me and others.
jimmy six
