Front brakes .... do you have them on your racebike?
Started by gowing, January 08, 2019, 04:18:37 PM
gowing
Simple enough question........ along with a why or why not would be great.
Personally, I have always liked heavy front ends on my bikes, (they just feel more "planted"),
so the additional weight of a dual disc setup is not a deal breaker to me. It just seems logical to leave it alone.
Does the unsprung weight of a front brake really make that big of a difference?
What are your thoughts / opinions?
stay`tee
i have left the front discs and calipers on (ballast), but thay are inoperatable,, activate the rear brake from the handlebar, reason being if you get a weave or wobble happening you can control it easier by hand from the bars,,
donpearsall
At least twice I have gotten into trouble using front brakes on the salt. Traction is so limited most of the time that it is easy to lock the front wheel and down you go. I went down coasting into the pit at a low speed by just touching the front brake lightly (wet salt). If you inadvertently lock the rear wheel it is not so much of a problem.
Some folks think the discs add aero to the front wheel... We always removed them... ran them one meet to decide if they helped, ran within a tenth and that was not consistent... Like I said... we always removed them... put the back brake on the bars and don't use it unless you are rolling to a stop.
No front brake on my bike to save weight and to reduce friction drag.
TheBaron
If you ever compete in the Runway Events,,,,, you will need them
Robert
We've always left the rotor(s) on the front wheel but consistently would back the pucks off the rotor before runs at Bville.  There's no doubt that we picked up some mph from that.
But then there was the time that we ran at the salt and immediately drove to Maxton for an event.  I distinctly remember quite an "Oh, SH*T!!" moment when I crossed the line and grabbed a handful of - - of lever, then another, a third, and on the fourth finally felt something starting to happen.
Note to self:  Remember to check brakes before a run.  And no, I don't remember how they got through inspection like that. . . :-o :-o
RansomT
On runway events, my bikes are set up that I never use the rear brakes to stop, only the fronts.  But, over the years I've also learned how to aero brake.
wfojohn
Quote from: RansomT on January 09, 2019, 04:31:54 PM
Ransom, what is aero braking, that is a new term to me. Thanks John
My guess for "aero" braking?  At some point once I cross the line and get out of the throttle I make sure I'm holding on and then sit the heck up and let my body take the wind to be the air brake, so to speak.  On the salt I cross the lie and get outa the throttle, and then, about 160 or so, start getting up into the wind.  Helmet, head and shoulders, full sitting position, and by then I'm well below race speed and starting to look for a turnout.
On short tracks there ain't the luxury of miles to run, so things need to happen a tad more quickly... :wink:
TheBaron
I also sit up as I pass the finish line to help slow down...
HOWEVER !  Certain bikes can and will go into a "Weave" caused by  turbulence vortex shedding coming off the upright rider....
If a bike begins weaving I've found it best to get as low and forward as possible to calm the event down.....
My bike is fine open w/o its fairing,,, with fairing and the "big tail" installed it has noticeable weave when slowing down till it is under 100 mph....
With just the front fairing it only has a slight weave condition that isn't serious at all....
Just be safe by being aware of this issue
Robert "Smitty" Smith
nrhs sales
all of my Bonneville bikes have the front brakes removed to include the rotors.  I also run the rear brake up to the handlebars as it is much easier for the rider to use and it helps when unloading from the trailer as well.
RansomT
A variation of what Jon said.  Purposely and controlled: raise head, shoulders,and then slightly slide forward raising more and allow elbows and knees to extended. Too quick and you get weave, and typically if that happens that is the only time I use the back brake.  I've run a many of shake down runs in the 190-200 range, and never touch the brakes until I get back to the pits.  Takes practice....also helped when I lived within commuting range of an event.
