Wanted Clevite rod bearings CB-610P
Started by ronnieroadster, February 10, 2019, 06:28:11 PM
ronnieroadster
Looking  for Clevite CB-610P bearings in standard size any quantity bearing is for 2 inch rod journal application is Buick and Chevy V-6 and 4 cylinder to name a few. Send me a PM if you may have anything or a lead on where to find some original Clevite 77 bearings
    Thanks
  Ronnieroadster
ronnieroadster
Quote from: jpm49c on February 10, 2019, 07:28:23 PM
Not sure this is what your looking for, but;
https://autoplicity.com/3465498-clevite-rod-bearings?gclid=EAIaIQobChMI7ICM2N2y4AIVsB6tBh30PgfnEAQYAiABEgK2C_D_BwE
  Thanks I noticed those but its shipped from manufacturer Mahle who now markets Clevite and substitutes a bearing thats no longer the tri metal 77 type. Using aluminum now.
Check out the King XP bearings.
ronnieroadster
Quote from: manta22 on February 10, 2019, 09:33:43 PM
  Already did theres no cross to the Clevite number King only makes an aluminum equivalent which is rated to under 500 HP.
      Thanks
See: http://kingracebearings.com/products-overview/xp-racing-line/
Note the similarity to an LSR application:
"It was developed for all performance applications that use forged steel aftermarket crankshafts and produce high loads for extended periods."
ronnieroadster
Quote from: manta22 on February 11, 2019, 04:59:27 PM
   Yes i realize that however they do not make the bearing I need in the XP series i even spent time talking with the King sales department the only cross to the CB-610P is their aluminum material so far at least maybe one day but not available at this time in XP.
jacksoni
The commonly available CB-745P SBC small journal bearing has same dimensions except the width. Maybe you could get them narrowed or there is space in your rod? Don't know the feasibility of that but ask your machinist/engine builder.
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
ronnieroadster
Quote from: jacksoni on February 12, 2019, 07:07:08 AM
    Thanks for the idea since Im the machinist and engine builder looks like Im going to get one and experiment.    :cheers:
revolutionary
Start with a CB-745HN which is already narrowed. Then you can stick in a rod and torque, then center up in your mill and use an angled tool to narrow it and chamfer at the same time. I used to do it all the time.
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
ronnieroadster
Quote from: revolutionary on March 14, 2019, 03:27:10 PM
    Good to know I did purchase a set of King coated rod bearings which were easy to machine for the reduced width. Used the trusty old Southbend and a fixture machined for the needed job. Same idea reduce width and chamfer all in one operation.
Ronnieroadster
