437 B engine for sale
Started by thundersalt, February 26, 2019, 02:00:03 PM
thundersalt
BIG BLOCK FORD 437 C.I. 825 HP                $9000 OBO
A 460 BLOCK
TRICK FLOW A460 HEADS 360 CFM
TRICK FLOW TUNNEL RAM (NEW) W/LINKAGE
(2)1200 CFM PRO SYSTEMS CARBS-BRAND NEW! (BUILT TO CAM & MOTOR SPECS)
MAGNA FUEL REG W/ALL HOSE AND FITTINGS
BME ALUMINUM RODS
FORGED STEEL "DUMP TRUCK" CRANK-FORD
MOROSO 10QT OIL PAN
KAASE OIL PUMP
JE PISTONS
MSD 8577 DISTRIBUTOR (NEW) + WIRES
MSD CRANK TRIGGER
ATI BALANCER
1.7 ROLLER ROCKERS
TRICK FLOW STUD GIRDLES
CVR ELECTRIC WATER PUMP 55GPM
CAMSHAFT- INTAKE DURATION @.050: 276
CAMSHAFT- EXHAUST DURATION @.050: 280
CAMSHAFT- INTAKE LIFT AT VALVE: .726
CAMSHAFT- EXHAUST LIFT AT VALVE: .692
EXTRAS:
SINGLE DOM TRICK FLOW MANIFOLD (TO MATCH)
AREOSPACE VACUUM PUMP KIT WITH 12-AN LINES
POWER MASTER MINI RACE ALTERNATOR
HEAR IT RUN ON A TEST STAND!!
2 RUNS AT EL MIRAGE SINCE FRESHEN UP
BY JOHN BECK RACING ENGINES
CHICO CA.
DYNO SHEETS SOON!
810 HP WITH SINGLE PRO SYSTEM 1650
916 REMR
El Mirage 200 MPH Club
