Frontal Area / Cd numbers
Started by Simspeed, April 19, 2019, 06:03:32 AM
7800ebs
I've done some work for  https://www.wrightspeed.com/  .  Interesting comment by an engineer there, when they cut power, the truck rear tires would "lock up". Sliding to a stop...
So plan on a programmable "ramp down" .
FYI.. I don't believe anything is "easy" when you are dealing with electronics and a salt environment.
bob
Simspeed
Quote from: 7800ebs on May 29, 2019, 07:52:43 AM
bob
Great point Bob...negative torque is created when one backs off the throttle and could lead to  the wheel motors locking up unless there are adequate programming controls to configure current routing between the generators and motors.  Woldesemayat & Nam (2017) identified causes and solutions that can be applied to controller programming to either eliminate the problem allowing coasting, or more desirably in this application induce degrees of electromotive braking to begin slowing the car as soon as the IC power is cut.  Braking rate can be programmed based on speed allowing the chutes to do their job initially and applying greater amounts of negative torque at lower speeds to bring the car to a stop.  The great thing about EV propulsion is that almost everything is programmable.  Thanks... Terry
References:
Lee, H., Woldesemayat, M. L., & Nam, K. (2017). Zero Torque Control for EV Coasting Considering Cross-Coupling Inductance. IEEE Transactions on Industrial Electronics, 64(8), 6096–6104. doi:10.1109/tie.2017.2681973
jacksoni
I would think a Vernier throttle more like small plane ( all I've flown were single engine) which can be "slammed" open or closed or twisted to gradually increase or decrease power would be better than just a "boat" like lever.
G/GCC- 194.580 2025
If you are using  PM DC torque motor, the braking torque problem is fairly simple. Since the motor is now acting like a generator, controlling the electrical load on the "generator" will control its braking torque. Polyphase AC motor braking torque control is a much more difficult problem.
Simspeed
Quote from: jacksoni on May 29, 2019, 12:12:45 PM
That may be just the ticket jacksoni; I've never flown an airplane so that throttle control is new to me.  I'll study up on it...thanks.  Terry
Simspeed
Quote from: manta22 on May 29, 2019, 12:22:13 PM
Hi Neil...yes the Yasa P400 RC gen/motors I'm designing around are 700v DC permanent magnet axial flux motors.  The standard 80mm cartridge model falls a little short of my peak power goals but Yasa offers custom windings to get there.   I'm confident stacked Yasa gen/motors and controllers can deliver what my power train design calls for.  Thanks for the info... Terry
TD
Very interesting discussion IMO, thanks for sharing it.   :cheers:
Sorry if I missed it, but I don't think I've seen mention of where the energy recovered under braking goes.  In a modern diesel-electric locomotive the generated power is dissipated as heat in the braking grid resistors mounted atop the car body.   In a contemporary EV the generated power is used to recharge the battery.
Tim
Doc B.
I am way out of my realm here, but don't most racing organizations require a throttle with a return spring that forces the throttle to always return to idle position if control pressure is removed? I wonder if a throttle that can be set in position like a boat or aircraft throttle (I think that is what is being described here) would be allowed.
Simspeed
#248
Quote from: TD on May 30, 2019, 09:10:56 AM
Tim
Hi Tim...no we haven't discussed where the energy goes when power to the wheel motors is cut and they effectively become generators feeding electromotive force back into the circuit that drives them under IC power. Up front I'm not an engineer...mechanical, electrical, or otherwise.  What I'm commenting on here is my understanding of how this circuit would work under the conditions described.  I may be half wrong or entirely wrong but I don't think so unless or until shown otherwise.
If the electrical circuit between the generators and motors is broken or disconnected there will be voltage but no current flow so the gen/motor mechanism will free wheel to some theoretical maximum voltage the circuitry can withstand. All well and good for idling or coasting but contributes nothing to braking.  When the circuit is closed however the gen/motors switch roles and electromotive force or EMF generated by the wheel motors is effectively driving the IC gen/motor connection.  The degree of force the IC gen/motors sees is determined by voltage the controllers are programmed to power the now reversed circuitry.
In my vision of the design, when power to the IC engines is cut (throttle off switches off ignition spark and fuel injectors) the 8 rotors and spinning generators become an active flywheel.  Reversed polarity EMF from the wheel motors attempts at low voltage to slow rpm of the flywheel and reverse rotation of both the generators and IR rotors. EMF Voltage is progressively increased as IC rotor rpm comes down to the point where the IC gen/rotors actually begin to rotate in the opposite direction and begin ramping up flywheel rpm absorbing braking energy generated by the wheel gen/motor EMF.  During the spin down to IC flywheel reversal the aluminum rotor housings and separator plates become heat sinks acting as resistors to dissipate heat build up in the gen units. The oil and coolant pumps all being electric motor driven would continue to run in standard rotation to keep oil and coolants flowing until IC flywheel eventually stops.
In a rotatory engine there are no valves or cams to contend with; reverse rotation is possible where the engine acts as an air pump under compression load dumping compressed air back into the atmosphere through intake ports and turbo housing.  When the car comes to a stop the IC flywheel is still spinning and can spool down under is own internal friction load.  I'm open to correction or clarification on any of this if someone with better knowledge knows reasons why this wouldn't work.  Thanks...Terry
Simspeed
Quote from: Doc B. on May 30, 2019, 11:25:14 AM
You may be right Doc... I'm not familiar with the rules on this.  it shouldn't be a problem if this approach isn't allowed.  We could work with a forced idle position spring by setting an EMF coast mode between between throttle up and full throttle off positions, where EMF braking would only be triggered in the throttle off/power off position.  Thanks... Terry
robfrey
I don't see it just locking up the wheels when you lift your foot off the throttle.
There are many ways to skin this cat.
Rob Freyvogel
#496
AA/BFS
Simspeed
Quote from: robfrey on May 30, 2019, 02:02:07 PM
Rob Freyvogel
#496
AA/BFS
I agree Rob.
Simspeed
I cleaned up the rear section of the car and shortened the chassis a couple of feet by removing the inboard support bracing for the outboard wheel motors.  I also added the chute tube and support structure and designed the chute cone doors to open and close with an actuator when triggered.  This design only needed 10° of movement to clear the chute path.  Don't know if that's enough to keep the tether lines from whipping them apart at speed.  We only have room for one 6" chute tube in this design, can we pack 2 chutes in that?  Thanks...
Simspeed
More drawings
robfrey
Looking better and better!
Rob Freyvogel
#496
AA/BFS
