Drawings for rear of GMC 302 or Chevy 235 for trans adapter needed
Started by Hans Blom, August 17, 2019, 12:34:29 AM
Hans Blom
Good day! I was wondering if anyone has the dimensions of the rear of a GM six to make an adapter.  I need to make a custom adapter for various tranny options. I asked over on the Inliner site as well to cover my bases.
Thanks for any help!
Hans
fastman614
Hi - I see that you posted several months ago nobody has gotten back to you. I do not have the dimensions or an adaptor plate but I could walk you through how to do it yourself.  I have made an adaptor or two over the decades. You could probably "get away with" using a good drill press although a milling machine would be preferable.
Or, alternatively, did you find someone who had what you needed already?
Either way, best of luck!
John Bjorkman
Here is a drawing of the block bolt pattern for a small block Chevy
Hope it helps
ggl205
Hans:
If you know somebody that is a member of the Automotive Engine Rebuilders Association (AERA) and has access to PROSIS engine spec software, they should have factory blueprints of the engine in question.
Speed Limit 1000
jimmy six
I've bought 3 from Buffalo Enterprises in Washington. Great product that fits. He will also do a starter ring gear to the crank flange if you want. He advertises in the Inliners periodical the 12 Port News.
