HANS - SFI/FIA
Started by neandethal, September 26, 2019, 08:18:59 AM
neandethal
i am about to buy a HANS device so i can set up my streamliner, but in the UK they only come with FIA certification not SFI, would this be acceptable to the boys at Tech? UK import taxes on stuff from the USA is crippling, 30% added on.
jacksoni
For this you probably should ask directly to a SCTA official. I don't see a specific person in the long list but would suggest Lee Kennedy, car technical committee chair: lee.kennedy@avmetrics.net  He can direct you to the proper person if he can't answer.
FWIW, in my personal experience using a Hans for 10 years now, they have never looked at the SFI tag, just said where is the Hans, see it, and go OK. Suit and other things that are specifically date limited (seat belts and helmets) get a close hairy eyeball.
G/GCC- 194.580 2025
Lemming Motors
Leatt MRX and Simpson hybrid Head and Neck restraints are both SFI certified and available in the UK. Not making any recommendation or comment on cost here but they might be an avenue to explore.
Just a squeeze.
deepindebt
Quote from: Lemming Motors on September 27, 2019, 02:59:36 AM
I have used both and I like the Simpson much better only because it is easier to bail out than it was with the Hans,just my 2 cents
327,B/GR
Lemming Motors
An update to this thread (and an apology to the thread initiator).
Apparently HANS (the company) have somehow brought pressure to bear on Leatt who have withdrawn their really nice head and neck support (SFI certified) to concentrate on the motocross market and the Simpson Hybrids in the UK DO NOT carry the SFI certification, just FIA.
I purchased the Leatt to set my car up - I need to check the rules and the SFI sticker now as it may well expire before I get to tech in 2021 with it and will not be re-certifiable by Leatt. It accommodated quite a large lay back seat position really well. I just spoke to the retailer as the link to it on their website doesn't work anymore and I was curious re spares. Bother.
Just a squeeze.
The HANS restricts the amount of forward head tilt & that becomes a visibility problem in streamliners due to driver lay back position. The Simpson allows you to get the chin of the helmet down to your chest but you will still need to have a helmet with a low enough visor to see forward in extreme positions. If you can use a HANS in a streamliner or a lakester your car is too tall.
jacksoni
There are different models of Hans for different positions and an adjustable one as well.
G/GCC- 194.580 2025
Quote from: jacksoni on October 07, 2019, 11:00:01 AM
Can you post a link to the HANS that doesn't have the chest plates that restrict the helmet? I can't find one on line!
jacksoni
Ok, I didn't totally get what you were saying and was thinking about the part at the back of the helmet. Sorry.
G/GCC- 194.580 2025
Quote from: neandethal on September 26, 2019, 08:18:59 AM
If you are just starting your build & you buy a head & neck now, it will probably need to be re-certified before you're ready to run. You might want to see if you can borrow one to design your seating, head rest & cage around. In the event of a crash, you need to have good shoulder & high back support, clearance for the head & neck & helmet support. As I said before, the Simpson allows you to get the helmet closer to your chest but you'll still need find a helmet that has a low enough visor opening at the bottom to make it work.
There are many well meaning people offering advice here on the forum but if they're not liner builders, that advice is a guess.
Packaging in a liner is a nightmare, 10-lb of $hit in a long skinny 5-lb box.
What are you building?
Mine is a AA/BFS-4WD & I have 20yrs of liners before this one.
johnneilson
I would suggest contacting Steve Davies of SCTA.
His contact info is at back of rule book.
That said, I have a very early version of HANS, before the SFI cert number established.
I took it to an inspection station and had the SFI sticker applied. No issues.
You can more than likely have this done when you bring car over to run it, just plan ahead.
Best, John
I haven't seen where their is an expiration date on a HANS device like there is on seat-belts and helmets.  Is it in the rule book somewhere?
Quote from: Sumner on October 08, 2019, 11:26:19 AM
Nope  :cheers:
My RaceQuip restraint has adjustable straps that limit the forward tilt of the helmet. However, I don't know at what point the helmet would contact the chest plates (I barely recline in my lakester). Also, the instructions say NOT to adjust the straps away from the manufacturer's settings.
Lemming Motors
Quote from: kiwi belly tank on October 07, 2019, 09:30:32 AM
My Lakester is too tall.  :cry: I made a conscious decision about the profile and seating position which may (probably) prove to be wrong  :-( but I?m having fun building it and I?ll own up to the outcome either way.  8-)
Just a squeeze.
