steel wheels
Started by bob, December 08, 2019, 05:58:17 PM
bob
any clues on custom made steel wheels 10 inch dia.   thanks
noboD
They will never fit over a rotor or brake drum.
bob
front wheels. no brakes on front. already have a beat up vintage 10 inch Mini Cooper wheel that I cut the center out  to check fit over spindles - fits ok.  thought of just buying a couple 10 inch mini wheels having the centers cut out , and new centers made and welded in. to get correct backspacing. anybody out there .
What Speed rated tire are you using?
Have you considered spun aluminum 2 or 3 piece.  Have you looked at ATV wheels, do you know what pattern you need?
bob
H rated yokahamas  5  x 4 -1/2  3 inch center - hub centric .  was trying to find 10 inch dia  steel wheel blanks . what I have now works fine .  but with the 10 inch yokahamas , I can lower the front fender humps 3 -1/2 inches. little better visibility looking forward. the a t v wheels or 2 piece aluminum could be an option , ill keep poking around .   thanks
You may also want to look at custom 10 inch wheels like I am having made by one of our members.  Sounds like they could be a spindle mount... skipping the hub centric and lug nuts.
http://www.landracing.com/forum/index.php?topic=12122.0
Just another option to solve your problem :cheers:
