Arm restraint clarification
Started by Clay Pitkin, March 15, 2020, 07:06:26 PM
Clay Pitkin
In reading the rule book, what is meant by "No two piece or welded "D" ring style adjusters for Arm restraints?
Does Crow, DJ Safety, etc, do they have these forsale in Summit racing, or how do I avoid purchasing these arm restraints?
TIA
Clay
Lemming Motors
Clay
Search the forum under wrist restraints - there was a discussion about the definition of this rule and you should find it that way. I purchased restraints from DJ and sent pics to tech and they approved them.
iirc the D ring adjusters (like the old chin strap adjusters on a m/cycle helmet) where there are 2 D rings side by side, with the D's made with a loop of 'wire' welded to close the loop, is out.
Just a squeeze.
SPDRACR
Contact Rick or Brad White at Autopower Industries 619)297-3300.
They manufacture them and race at El Mirage and Bonneville.
salt is OK, but the DIRT is where it's at!
Proud 2nd generation Roadster Racer
Muroc 2 club, El Mirage 2 club, Now Bonneville 2 club,       All in a Roadster
kustombrad
Not to sound dumb, but are there any arms restraints out there that AREN'T fastened with Velcro? No offense to whoever designed the stuff, but I really don't feel like trusting  any body parts with some fuzzy plastic...
7707
I use DJ Safety arm restraints simple as that. Check with Kiwi Steve but they have to be approved.
Set records (A/BFRMR) at 258.679mph, 277.869 & 289.239mph Member of the Bonneville 200mph Club. Just trying to go fast!
Look for our Facebook page ...  Geoff Stilwell
trimmers
Yes, this was discussed at length on this board previously.   Arm restraints with two welded D-rings CAN be used, but the D-rings can only be used as attachment points - with the strap passing through both of them together, rather than through one then the other.  They can NOT be used to set/adjust the length of the straps that restrain your arms as it was discovered that (in a high-G impact) the straps can slip through them and allow your arms to come free.
Rather, the adjustment of the straps' length MUST be accomplished by threading them through a flat, figure-8 shaped bar - like a smaller version of the flat bars that are used to securely adjust the length of shoulder harnesses.    Anyway, the key is adding the flat, figure-8 bar.  Kiwi Steve did have a bunch of them.
Jeff in Boise
------------- 1 of just 3 in all 3  -------------
USFRA 130 MPH Club 09/18/2008 136.757
USFRA 150 MPH Club 09/17/2009 152.162
Bonneville 200 MPH Club 09/15/2019 218.600
Best Run: 253.080 MPH 09/14/2019 #6556
