Average horsepower needed to reach 200mph at Bonneville with a full size truck?
Started by Maicojoe, July 01, 2020, 12:42:43 PM
Maicojoe
Just a quick question for the guys that have already done this.... on average, for a full size, standard cab truck, specifically a 1995 Dodge with standard bed, what would be a reasonable horsepower needed to reach 200 mph at Bonneville? No real mods to the truck?s body other than to remove the side mirrors, and possibly a front spoiler to keep air from going under the truck and causing lift, and the same for the rear, a bed cover and small spoiler to keep the back end planted for traction. The 1st gen Dodge Ram trucks, just looking at them, they look quite a bit more aerodynamic than say my 2006 Dodge truck?
deepindebt
Your wallet equals your HP,so make as much HP as you can afford and take it from there.So much more that goes into flat out speed but the money to make the DEPENDABLE HP is huge!
327,B/GR
jimmy six
Go back and get a 49-53 long bed. Spend your 401K and max out 2 credit cards and that will get you close. . . . . . maybe
jacksoni
Other than the bring money answers you have gotten a rough guess might be: 0.45 Cd. Could be less and there are legal things you can do, depending on class that can help that. Frontal area 34sqft (stock 72" tall, 80"wide more or less. usually take 85% of that for rounded corners.) Lowering the truck definitely helps and will lower the frontal area a lot as the above is the advertised height). I used 4500lbs in the Wallace calculator. That gives range of 850hp. I'd say add a hundred to that to actually accelerate reasonably. Quick playing with Bonneville Pro suggests will need more but I'd need to spend some time to put decent inputs into it.
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
ronnieroadster
If you look at a few current records over 200 MPH set with a Dodge full size truck.  The engines of choice are older Nascar type. Which average at least 850HP.  Not spinning out during the run has been one of the areas that even the best combinations seem to have issues with at times.
Ronnieroadster
This might probably almost certainly be what us bike guys deal with.  A sit on bike with a rider in upright position is sorta like a full size pick up truck.  Somewhere around 180 or 190 mph is the fast the combination can go.  The big frontal area puts the CP to far ahead of the CG.  It is a marginally stable combination at best.  No amount of added power can cure the problem.  The 150 club might be a good goal.
I'd rather spin in a full size pickup with a cage than spin on a bike.
"Quick playing with Bonneville Pro suggests will need more but I'd need to spend some time to put decent inputs into it."
Talk to Bernie Brown with the big red truck from Texas
Some of the Dodge records a b'ville were set with tailwinds so high that the course should have been shut down---- YMMV
Big Tim would probably tell ya to keep adding boost till you get there....  :cheers:
Maicojoe
Thanks to all that responded, much appreciated. The horsepower is pretty easy to achieve with a 5.9 Cummins, 1000 WHP nowadays is pretty achievable, and still be actually streetable to drive everyday. The technology and aftermarket parts are what makes that fairly easy. The cost for a 1000 hp 5.9 Cummins is about $15k, but it will last 100k miles if properly done. The part that worries me is what some of you are saying is a full sized pickup truck is inherently unstable at speed.... hmm, how does a Craftsman NASCAR truck stay stable at  200mph? Aren?t they ?roughly? a full size truck? Granted, they are lowered, have good front and rear spoilers with a tonneau cover, and probably a partial under body pan. All something that is pretty easy to accomplish with my truck. Heck, I bought brand new, and still own, a 2005 Dodge Ram SRT10 truck, stock it was 500hp, I added about 50hp via exhaust, custom ECM tune, and a CAI. At 550hp, it does exactly 160mph before the rev limiter cuts in, with an old style 4spd automatic that is stock, both on the street and on the dyno. Granted, that?s on pavement, but that truck is no way as slippery as my 95 Cummins, just eyeballing the two next to each other. I definitely need to do more research, there is no sense in building an unstable rig. Thanks again to all that responded. Joe
Maicojoe
Maicojoe
Maicojoe
My 2005 Dodge SRT10 truck that does 160mph on pavement. My 1995 truck just looks like it has better aerodynamics.
RansomT
Quote from: Maicojoe on July 07, 2020, 04:10:07 PM
Far from it.  They are a Steel Tube Frame vehicle that has nothing in common with a production truck.  Think NASCAR car with truck sheet metal.
And for your speeds that you are quoting...how is that determined?   PLUS, in the motorcycle world, it takes about 200 wHP with stockish fairings to go 200.  It takes 450-500 wHP to go 250 mph.  At speed it typically takes not twice the HP to go twice the speed but squared or more.
