Harley Front Wheels
Started by ggl205, November 24, 2020, 10:32:20 AM
ggl205
Here is one for all you Harley techs out there. I am converting my 2003 Sportster 19 inch front wheel to run as a rear. I have another front Harley wheel that is thought to be either a 1988 or 1994. Will either year fit my 2003 Sportster as a front wheel?
TIA,
Old Scrambler
Please use shouldered bolts for the sprocket...........almost anything is possible on the front if you don't need a brake.....
John, there is a big shortage of rear tires with high speed ratings for 19-inch rear rims.  There are some flat track race tires but those bikes do not go as fast as land speed ones do.
ggl205
I should have been more specific with my request.
I was given a 2003 XLH 883 Hugger that I want to make into a street tracker. I was also given a 1994 19? front wheel that does not work with my J&P front wheel conversion adapter kit to make into a rear wheel. So, I was wondering if the 1994 front wheel will work on 2003 forks and rotor disc.
Sorry for the confusion.
floydjer
ggl205
Thanks everyone. I got the information I needed.
salt27
ggl205
I found a near perfect year 2000, 19 inch narrow glide front wheel that works with my Vulcan front to rear wheel adapters. This wheel has 1 inch axle bearings so Revzilla helped out with reducer bushings to 3/4 inch. This allowed me to retain the stock 19 inch front wheel on the bike now.
salt27
John, Do post some pictures when you get it done, trackers are cool.
ggl205
Shouldn't you be working on the lakester while the weather is nice?  :evil:
ggl205
Stainless, I need an engine to finish everything that is left. Anybody?s guess when that happens. Besides, the good weather is over and I need something to keep me out of trouble over winter months.
