Rear Wing Design
Started by rmcmullin, January 26, 2021, 09:47:17 PM
rmcmullin
I?m adding a wing to my rear engined modified roadster.  Is there anybody in the business who produces an off the shelf product that would be better than just making a guess?
You could build one yourself. I'd recommend a NACA4412 profile. A long time ago I built one of aluminum for a friend's FE AA fuel dragster. I think I still have it around here somewhere.
RichFox
Get ahold of Bob Dalton at D&A Engineering in San Martin, Ca. Or look up Flashpoint on Google. Nothing he likes better than talking about and making wings. I don't know how much time i have spent listening to him telling me about wings. And he has the tooling to knock one out real fast.
I have got to agree with both Neil and Stan, the NACA4412 is a great wing section, low drag and high efficiency. Bob Dalton had a couple of wings on his Flashpoint streamliner and he ran over 450 with 2 wheel drive so they must have been working (Of course a top fuel motor on 85% soda pop helps!) If you want to build your own I would suggest contacting Woody at Design Dreams and he can help you to select the proper design and also with the info you need for making it. Building a wing is not hard but there are lots of ways to do it. I have done aluminum wings but I think the best wing would be built out of fiberglass or carbon fiber with a foam core. Lots of info on You Tube on how to do it.
rmcmullin
Thanks to all for your advice.  I?ll contact Bob Dalton and see if he can give me some help.
RichFox
Spoke to Bob yesterday. He knows you may call.
panic
Assuming the wing width and cross-section is fixed, the angle of attack will depend in part on the terminal speed. The lower the speed, more nose-down attitude (higher drag with higher downforce) helps. Each wing shape probably has a range of angles at high efficiency. Horizontal may not mean lowest effect + minimum drag if it's receiving air off a roof, back light, etc.
High wing placement increases efficiency by avoiding air disturbed by the bodywork, and also increases cantilever weight transfer.
rmcmullin
Spoke with Bob, and he was a wealth of information and good advice.  Thanks to everybody for the reference.
