Search photos of Sunrunner
Started by seanfranklin, November 11, 2021, 09:29:16 PM
seanfranklin
Troubleshooting the shark navigator lift-away nv360
Just got a brand new Shark NV360 Bagless, lift away deluxe vacuum cleaner but something seems to not be right? Don’t worry, we’ve got you! There are about a gazillion things that can go wrong when using a vacuum cleaner, but this article seeks to address the three most common problems and guide you on how to troubleshoot.
Read The Article: Shark vacuum NV360
Number 1: My vacuum won't turn on
There might be something wrong with the power cord. It needs to be stored in a dry place with room temperature when not in use. A heated surface risks damaging the cord.
Check to see if there is any problem with this cord. A broken one can be fixed with duct tape, which you can seal around it. A leaked cord cannot provide enough electricity to power the vacuum.
Tips on how to maintain the power cord
To prevent damaging the power cord, never drag nor carry the cleaner by the cord. Never put too much pressure on it, such as closing a door or pulling the motor over it. When unplugging, do not yank the cord but pull by the plug. Finally, Shark themselves do not recommend using extension cords as they may transmit too much or too little electric current.
  • Number 2: The vacuum does not pick up dirt
There could be 3 possible reasons:
#1: The dust cup might be full-- the vacuum will not take on any more dirt than it could contain. Check and dump the dust cup to get rid of dirt.
#2: The filters are clogged by dirt. This might occur when you have used your blue Shark Navigator Lift-Away Deluxe NV360 for a while. To solve this, simply remove the filters and clean them. All filters - pre-motor foam and felt filters, as well as the HEPA filter - are removable from the machine, making it easy to clean. Run them under water until the water is clear. You have to do this by hand, since tossing them in a washer might damage the fabric. After cleaning, simply let air-dry for approximately 24-48 hours.
#3: The hose might be clogged, so you might have to check and see.
Once all of these openings have been checked but the vacuum still does not work, check for blockades elsewhere. Blockades are one of the main obstacles for air flows, restricting the suction of the machine.
  • Number 3: The brush does not spin
Check to see if the switch on the handle is on the “II - Brush Roll On” mode.
If this does not work, immediately turn off the vacuum and check for blockades. Blockades can overheat the motor, making it dangerous for users and damaging to the motor. Pull the handle and detach the floor nozzle to disengage the “Auto-off” feature. Once finished, put the nozzle back on, reconnect the vacuum, and ensure that it’s on the right more.
Tips on how to make the most of the options
The “I - Bare Floor” option works best on non-carpet, plain floors like tiles or laminate. This is where the dusting brush does not spin and the vacuum simply pulls dust up in a straightforward manner.
The “II - Brush Roll On” is for carpet - both gor high or low tile - because the brush rotates to drag along dirt and hair. This brush might, nevertheless, damage the carpet. If your rugs or carpet are hand-woven and especially delicate, make sure to relax the suction power or switch to suction only when vacuuming mode to avoid shredding them.
Above are three of the common troubles encountered by users of the Shark NV360. If you find this guide useful, please share to those who need it!
OK, I don't remember that car... can you start with a brief description of it before any of us start searching through old pictures.
Sundowner, yes.  Sunrunner, no.  The time frame works for Sundowner...
That's why I wanted a description Slim... I think I posted a Sundowner pic in old Bonneville pics some time ago.
Dynoroom
I have a vague recollection on the name Sunrunner or some such. Was it a streamliner like the one pictured?
I've just been wondering if it might have been one of those university solar racer projects. It may not have run at any formal event.
modernbeat
Might be a University car.
There was a 2007 event for them.
The Electrathon
WOODY@DDLLC
speedrelic
Sean Franklin, is it the #88 Burke Brothers streamliner that crashed? if so I have some.
Well everyone... I guess we are waiting on Sean to let us know a description of the car he is looking for.
Until then...  :dhorse:
Yes, I guess you're right, Stainless.  I've been frustrated trying to put together a photoshop-type image showing a late '60s Plymouth performance car with the special-edition convertible top that was operated by a solar cell apparatus.  Remember that one?
floydjer
Was it one of those floral pattern tops??? Sunflowers perhaps?
Most of the cars I've seen with floral patterns was during the 60's not the mid 80s...
that and the one Jerry drives to work  :cheers:
floydjer
Those  flowers are rust holes Bob...
