Oddball forced induction
Started by roblebel, December 15, 2021, 01:16:51 PM
roblebel
As forced induction gets caught up with the 21st century and electronics that just get better and better, does anyone know the SCTA's take on electric blowers?
bearingburner
When I was at Bonneville in 1971 a biker ran a Harley in the supercharged class using a automobile heater motor
and ductwork.
bearingburner
When I was at Bonneville in1971 a biker ran a Harley in a open supercharged class using a automobile heater blower and motor.
jl222
#3
  It's ben 20+ years but there was, is, a company near Carpenteria Ca that was making electric powered turbos
( centrifugals ) for autos , of course I was told by a well know Bville racer it couldn't be done.
Turbodine maybe?
Not for cars but forgot to tell him to look up when leaving the car wash.
salt27
If intended for an SCTA event an "artificially-aspirated engine" will have the blower mechanically-driven and/or exhaust driven by the engine.
Section 4 definitions, 4.FF
MRK
Quote from: roblebel on December 15, 2021, 01:16:51 PM
To answer your question, the subject of electrically driven turbochargers has been discussed along with other for form of forced induction that would be considered "illegal" under today's rules. There will not be any changes to the rule for 2022. As far as I know there has never been a rule change request to allow electrically driven turbochargers specifically. You are more than welcome to submit one. The form can be found on the SCTA website.
Cheers
roblebel
Appreciate all the reply's folks. My rule book still hasn't arrived so this kind of input is really helpful. I
Quote from: MRK on December 15, 2021, 08:57:24 PM
JimL
#7
A small bit of history with the electric "Turbodyne" blower:  I was lightly involved with a test of prepping some "Long Beach Celebrity Race" 1994 Celicas' for a proposed celebrity event for Pikes Peak Hillclimb.  The blowers were set up to run on 42 volts, with an oversize alternator arrangement to feed extra batteries in the rear of the car.
We found that the stock fuel injection could not be allowed to exceed 4.3 psi without popping the internal silicone plug in the MAP sensor.  We were doing a little "testing" late at night on some back streets in an industrial area.
The battery drain was so extreme that the cars were not going to be able to run the event distance.  Our joke, at the time, was that the drain was so extreme....we could see the headlight beams sinking toward the ground in a curve, in front of the car, when we tried full throttle!
I was told the primary (intermittent) use for the Turbodyne units was "start from stop" traffic conditions for diesel delivery trucks.  I understand they would allow smaller, more fuel efficient, and cleaner engines to do the delivery work needed.  It sounded like a good idea for that application, but a dead end for anything longer than a few seconds of operation.
OK, here is an oddball forced induction idea- Take a turbocharger and instead of driving the impeller with engine exhaust gas, drive it with a gas generator (not a gasoline powered generator like a Honda or Homelite) such as a hydrogen peroxide steam generator or a pyrotechnic gas generator. It might not last any longer than that Turbodyne electric blower but it's "oddball" (read: harebrained")  :-P
jacksoni
Youtube is full of videos of electric turbochargers on dyno and strip. They work. How long do they last? OK, flip the switch at, say, the mile and run to the 3? On a small motor class. The possibilities are endless..... lol8 muutt
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
MRK
This is the system that's been pushed in recently rule change requests...
http://casupercharging.com/
jacksoni
And Hey, didn't Freiburger et al from Hot Rod run a Monza at Wilmington (ECTA) with a bunch of leaf blowers for "supercharging" (also not allowed in SCTA rules- multiple engines and not driven by the primary etc)
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
Well all forms of forced air induction should be in blown class.... Bottled air included...
I don't see the issue with electric driven blowers or bottled air... what am I missing?
tortoise
Quote from: Stainless1 on December 17, 2021, 12:18:20 PM
Turbo or mechanical supercharging is powered by the engine. Using additional power sources is an unfair advantage.
MRK
Vintage classes using vintage engines too or keep mechanical driven superchargers as the sole means of forced induction?? Not challenging you just looking for comment as the rule gets discussed further.  :-D
