Cast iron repair
Started by John Burk, February 11, 2022, 04:38:07 PM
John Burk
Funny you should post that, I just watched it today while having lunch.
donpearsall
The video was interesting. I did notice that the welder kept complaining how hard cast iron was to weld because of contaminants, and then did not even bother to remove the paint from the area he was welding.
floydjer
I repaired a cracked bell from a friend's centennial farm a few years ago. Once was enough .
panic
It helps having an oven big enough for pre- and post-weld temperature control, the longer-&-slower the better.
Even a well-insulated box (old refrigerator?) is better than air cooling.
bearingburner
When I was a Maintenance Manager we had a large cast iron hydraulic cylinder which had a mount broken. We sent it out to a facility witb a LARGE oven
and the welder got in the oven to do the welding. Cylinder must have been 10' long. They pre heated the cylinder for 24 hrs and then cooled it in the oven for another 24 hrs.
Pre-heating cast iron and then braze welding works very well.
The last road grader split trans case I repaired was with it still in the machine I welded it with a Blue Max 2100 rod. I bolted a 1/2" girdle plate to the outside then welded the housing to the plate from the inside. Not pretty but it's been working 6yrs since then.
WOODY@DDLLC
Quote from: manta22 on February 12, 2022, 04:35:13 PM
That will keep you from chasing the crack! Don't ask me how I know!  :-P lol8
floydjer
My plan for the bell was to tig braze the crack until the old geezers on Shopfloortalk.com offered the bell would not "ring true". So...Pre heat with a rosebud, pass the torch to my right hand girl to maintain heat and stitch weld with stainless wire and gentle peening. Sounds O.K. Hasn't cracked.
jimmy six
Send your cast iron parts to Pakistan... those guys can fix anything :cheers: lol8
mtiberio
Quote from: jimmy six on February 13, 2022, 10:45:18 AM
Oh god. I saw a video where the Paki mechanics on a dirt floor garage built up a broken ring gear tooth with a stick welder. "Lapped" it in with a die grinder... I wonder how long that lasted...
floydjer
The Pakistani gas welding damaged aluminum wheels using hand poured filler rod is inspirational as well.
