Early V-8 Ford U-Joint
Started by Stan Back, March 13, 2022, 11:15:47 AM
Anybody got a pretty good estimate of how many H.P. one with 5? or 10? angle would take at say 5000 RPM?
. . . common, I won't hold you to it.  Something you've heard, a wild guess, whatever.  They gotta take something and the increase of angle might increase the loss.
ronnieroadster
Are you asking if the clutch is side stepped at 5000 RPM? The few small block powered hot rods I recall still using that six spline early Ford U joint combination were only putting out less than 400 ponies. The failure experienced was the drive shaft it broke easily the u joint stayed together.
Ronnieroadster
Thanx, Ronnie.  I'm just trying to get a HP loss (if any) using one.  And if the loss is greater with increased angle.
(On a side note, on my roadster when it was a street car, I never broke one.  I broke almost everything else, but I think with the Hydro (modified) and 30 lbs. of air in the 8.20s, no non-sliding shocks were hard to come by.
Stan
WOODY@DDLLC
Thanx, Woody!
My steam-powered Mac this year has decided that it can't open certain documents to my dismay.  That is one of them. My machine says my clock is not right.  I've tried to fix it to no avail.  I'm thinking of hanging around the junior highs to find someone who knows what this means and can fix it, but don't want to be picked up on any related charges.
May haps could you paraphrase it for me?  I won't hold you to it.
Interested Observer
Stan:  Woody?s article said nothing about power loss and nothing else on that website dealt with it either.  Mostly discussions of advisable/permissible operating angles.
At 5 degrees, I would guess not enough power loss to be concerned about?probably comparable to windage of the drive tube.
WOODY@DDLLC
Stan, technically anything with bearings has a HP loss but this is not worth trying to calculate, IMHO!
Will it take the torque at a certain RPM, angle & load?
This means spike loads not just constant loads the supplier specifies. {Think changing loads with traction control on the Speed Demon!  :evil:}
To Ronnie's point the driveshaft has to be better material or heavier wall or attached better, etc.
Hot Rodding 101 - if it breaks - reinforce part A until part B breaks - then reinforce part B - until $$ run out!  :?
Most driveshaft folks don't want more than 7 degrees but more can be tolerated with some vibrations & shorter life. Don't forget any pinion wrap-up with your suspension.
Looks like I paraphrased a bit more than I.O.  :roll:
