Items wanted
Started by fissionspeed, May 24, 2022, 02:28:01 PM
fissionspeed
Hi all, I've decided to put all the "needs" for my build in one thread, so I can bump it as the list changes. If you live within an hour or two of Socal (or the item is shippable) and you have any of the following, please reach out!
-1.625 x.120 mild steel DOM tubing
-JD2 tube bender/dies/stand
-15 inch LSR wheels with 27-28 in tall tires (used ok, flexible on size. trying to do mockups for the suspension) + MOON discs
-200mph fire suit (I am 6'0, 220 lbs. Aiming for 180lbs race weight  :-P)
-200mph fire system
-Parachute kit
-Racing seat
-Harness/arm restraints
-HANS
-S10 lexan windows
-Weld-on 9 inch ends
And last but not least, anything you think I might need! I'm building from zero so if you think I need it I probably do!
wheelrdealer
Where are you located, I  have several sets of 15" fully welded steel wheels  with Moon disc Dzus tabs welded on.
I have a 10lbs Firebottle halon system with mount, valve and  pull cable.
I'm in SW Michigan.
fissionspeed
Jack Gifford
I have a never-worn Stroud -20 2-piece firesuit that may fit you.
See my posts in another current thread of this forum.
M/T Pontiac hemi guru
