Need for Speedweek- Hilborn nozzles
Started by GD, July 18, 2022, 02:25:49 PM
GD
Wanted for Speedweek- one set (4 left and 4 right) Hilborn non- of air bleed type, or Kinsler #8 nozzles.Would also consider #10?s. Holly has discontinued all the Hilborn mechanical injection, and Kinsler is 6-8 weeks delivery. If anyone has any available please pm me or text or call 403-619-three six two four. Donation to be made to this site if I find some.
Thanks
Gord Driedger
Gord Driedger
53 Studebaker
Record holder Speedweek 2016 XF/FCC 162.698
Record holder Speedweek 2016 XF/GCC 158.978
fwillyj
#1
---there's a guy named Spud Miller---at--http://www.fuelinjectionent.com
---he bought Mallory's ignition department and has also built a nice fuel injection business
---search Spud Miller and give him a call at 541-990-2485
GD
Thanks. I?ll find his # and call him.
Gord Driedger
53 Studebaker
deepindebt
Alkydigger is another good source
615-457-3192
327,B/GR
GD
Thanks I?ll try him next. Spud didn?t have what I need.
Gord Driedger
53 Studebaker
fwillyj
---I have eight #8AS---short straight tip ends---hose connections are 90 degrees---they have four aeration in holes
---I think these are brand new
---I also have 4 lefts and 4 rights---#6 deflector tips---90 degree hose connections---two aeration in holes
---I flowed these and all 8 flow 30PPH each which is 240 PPH total at 30 psi fuel pressure
------------------------all 8 flow 38PPH each which is 304 PPH total at 60 psi fuel pressure
---these 6A's are new
---if these would help in any way I could probably work out some sort of deal
GD
Thanks for the offer but unfortunately I don?t think those will work as this is for a blown application so I need solid nozzles, not the ones with air bleeds. Anybody else have any? I would also be willing to rent a set for Speedweek if you have some that you don?t want to sell. So far all the suppliers and manufacturers are at least 6-8 weeks delivery.
Gord Driedger
53 Studebaker
fwillyj
#7
---this link is to a guy named Dave Koehler
https://www.koehlerinjection.com/enderle-fuel-injection-nozzles-jets.html
---he shows Enderle nozzle 2 piece bodies---maybe they have to be soldered together
---or maybe he has some other stuff
---I have used some crimp on hose clamps like Oetiker to surround the nozzles and crimp'm on there to basically seal off those air holes
---and I have also made circular pieces that fit on with a press fit----that have connections that I can run to a common air source manifold---like to get the ram air or boost air pressure into all the nozzles
---this is a long shot but there's a guy in Australia named Ken Lowe who does fuel injection
http://www.kenlowe.com.au/
---might want to e-mail him and see what happens
