Front wheel drive assy. for streamliner
Started by racergeo, July 19, 2022, 10:16:17 PM
racergeo
  I'm offering a new FWD assembly out of an older (early 90s) streamliner that was never finished. It would be perfect for a lower engine class car in the under 700hp range. It is expertly built and Tig welded. It is based on a Dana 30 diff. and a Casale parallel shaft gear reduction unit. The setup was originally intended for a 260c.i. Dodge hemi.The Casale is new and has 24-39 tooth count. The steering linkage and custom 15" wheels are included. It is 31"wide to the outside of tires. It could be modified to be about 4" narrower. See the photos. If you are interested I have pictures of the inside of the Casale. I also have two new M/T 24.5 -16 tires that are New Contact me for price and arrangements to deliver to Speed Week. George 360-481-3368
