SOLD Complete RacePak Data Logger Dash, Sensors VNETS and Much More SOLD
Started by wheelrdealer, February 28, 2023, 04:51:41 PM
wheelrdealer
IQ3 Logger Dash Bundle, 35 pieces, plus some spare plugs and pins. Almost everything you will need to install a RacePak Data Logger Dash in your blown/turbo/NA race car. For specific information please see RacePak.com. $35 Shipping lower 48 US States only. $800 for everything listed with 10% going to SSS for support of this great forum. With shipping $835. There is a few thousand dollars worth of RacePak gear here so I am not open to offers. This data logger is listed on other sites so first come first sold. PM me and I will use the time date stamp to determine a tie breaker. Thanks for looking.
Slim, I have pictures if you can post them.
?   (1) 250-DS-IQ3D Logger Dash, used but in great condition
?   (2) 230-VM-USM-V2 Universal Sensor Modules, (use up to 8  sensors you choose to manually program)
o   (2) USM VNET 9?  CANbus Cables
?   (1) Drive Shaft RPM sender w/ 1.875 drive shaft ring
?   (1) 0-15 PSI Fuel Pressure Sensor, with plug in lead
?   (1) 0-100 Oil Pressure Sensor, with plug in lead
?   (1) 0-300 F Water Temp Sensor, with plug in lead
?   (2) GPS Antennas with leads, 1 used and 1 new in bag
?   (1) Data to PC Transfer Cable
?   (1) Microchip to SD Holder with (1) Micro Chip
?   (5) CANbus Extension Cables
o   (1) 36?
o   (1) 46?
o   (2) 17?
o   (1) 22?
?   (1) Bulkhead Connector
?   (2) Male Terminator Plugs
?   (2) Female Terminator Plugs
?   (1) VNET Oil Temp -300 Degree Cable and Sender
?   (2) Bosch Wide Band VNET Controllers
o   (3) Bosch 02 Sensors, Used
o   (2) Bosch O2 Sensors, New
?   (1) 230-VM-Relay Controller, (turns on relay) New in Bag
?   (1) Intake Air Temp Sensor with Lead for use with USM above
?   (1) 280-CA-HARNIQ3L  IQ3 Master Harness, NEW
?   (1) 280-CA-HARNIQ3L  IQ3 Master Harness, Used
?   (1) 220-VP-PT-PP075 Fuel Pressure VNET Module, NEW
?   (1) 810-SN-AFAMP 220-VP-PT BVAC VNET with Sensor
?   (1) 230-VM-GPHERO VENT Module turns on/off Go Pro HERO 2 Camera, Links camera start to start of Data
?   (1) 230-VM-EFI-CAN VNET Module for EFI, See RacePak website for supported EFIs
?   (1) 280-CA-EFIOBDII Module Adaptor OBD link to factory OBD II Plug
?   (1) RacePak Installation Manual
?   (1) RacePak VNET CD
racergeo
   I tried to Pm you to buy this. It says you can't be found :laugh:  Any way I like to here from you Thanks  George Johnson
wheelrdealer
I just sent you a PM and it says it went through. All of my contact info is in the PM. Thank you, Bill Reilly
DallasV
wheelrdealer
Thanks for everyone that looked and those of you that inquired. George, Thanks and good luck. Its cool to know the 2100's data logger dash will go down the Bonneville salt course again.
Slim, Donation made this morning. Thank you.
Good luck and good racing all,
Bill Reilly
