Complete C-4 Transmission with lock up converter LSR combination
Started by ronnieroadster, March 16, 2023, 10:46:51 AM
ronnieroadster
Changing combination for this season so our race and record holding combination is available. This C-4 Ford transmission is stock length its fresh and ready to run it has a manual standard three speed pattern it is not reversed. Every internal improvement possible has been done to this combination including REM polishing plus roller and needle bearings first gear is the tallest available strictly for LSR . Lockup is controlled by a solenoid triggered by a manual switch or timing system actuated by throttle position the timer is included. Transmission designed built and serviced by Dynamic Racing Converters
Top speed so far 229MPH used in vintage X/F and XX/F engine class. I have pictures of the combination however I'm unable to attach them for some reason.
    Asking $6900.00 shipping which can be arranged if needed would be extra.
          For more info please send me a PM
                     Ronnieroadster
