Vortex generator
Started by deepindebt, March 30, 2023, 10:58:31 AM
deepindebt
Has any one used small VGs inside an air intake before the plenum? I think it may be a positive? Thoughts?
327,B/GR
Air inlets and scoops that actually are efficient enough to increase inlet air pressure are not as easy to build as they look. We had Woody design one for us and he went through a bunch of concepts and design before we got one that worked. As I remember none of them had vortex generators. Our scoop has guide vanes and a splitter but nothing you would call a VG. A properly designed NACA duct works because of the vortex(s) that are generated on each side of the flush opening. If you want a scoop that works contact Woody.
panic
NASA once had diagrams of various NACA shapes and proportions on line, can't find it now.
The pressure (discharge) side of serious superchargers (all Eaton "M" series, Kobelco) look suspiciously like NACA ducts: they're much smaller than the area of the rotors, and heavily biased toward one end of the manifold.
Speed Limit 1000
Just GOOGLE "A NACA duct calculator" lots of information comes up. I have an original NACA paper, I believe from 1947, but I'm in Costa Rica so no access at this time.
TheBaron
Vortex Generators are a "positive" addition when there are increased drag issues from "growing boundary layers" on airfoils....
Otherwise, they are just protrusions in the airstream that ,most likely, will hurt more than help...
Smitty
Woody or at the very least the special air cleaner/air calmer on top of carb or throttlebody
