Bell mouth rules
Started by deepindebt, July 22, 2023, 04:35:38 PM
deepindebt
Is a bell mouth considered tapering?
327,B/GR
can you explain the rule in question you are asking about....maybe section and part?
deepindebt
This is for a gas roadster, did a new air intake through grill shell. Page 46 section 4.B says shall not taper. I didn?t think a bell mouth is tapering? Came up on a post I put out on FB and somebody said it?s illegal? I would think it would be stated in rule (bell mouth). Not the end of the world just curious.
327,B/GR
jacksoni
Although the language stating that just because someone else did it and were not questioned or disallowed, does not mean that YOU can do it (in impound-drat). Point being I have seen a bell mouth on the front of many cars (including mine at a time) and nobody said boo. Can't imagine a bell mouth of 48sqin but you do occasionally see rectangular pipes sticking out through the radiator area on roadsters presumably to supply ram air.
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
kiwi belly tank
How do you consider a bell mouth to not be tapered? It's a tapered expanding or reducing opening depending on which direction the air is flowing!
MRK
