Bonneville- El Mirage gas-fuel roadster
Started by cheap-n-dirty, March 10, 2024, 06:02:29 PM
cheap-n-dirty
$30,000
1928 Ford bodied Bonneville-El Mirage legal gas/fuel roadster. Real 1928 Ford roadster body and 1932 Ford frame. Legal roll cage and drivers seat. full car less race engine and rear wheels and tires. Has 5 gallon fuel cell in front, rear mounted radiator and 5 gallon water system and all hoses. has race prep power glide , includes direct drive (eliminates torque converter). Set up for big and small block chevy engines. has 2 5 lbs. fire bottles (needs to be date certified). Has SCTA chassis tag.
Last ran at World of speed in 2012, it ran 197 mph in the 2-3 mile on a license pass. At the end of mile one was tacking 200 mph. includes Stroud parachute. Kirkey seat and cover.
Link to video of runs at World of Speed.
https://youtu.be/EOXfJb4ot3A?si=rtvoTnBZmanQGaKO
Also available 540 cubic inch big block chevy race engine.
Call or leave message 208-452-3449
001 bville 2009.jpg usfra 384.jpg asselmbly 008.jpg new pictures 3-08 014.jpg nov 8 2012 009.JPG poweer coated frame 002.jpg w o s 2012 026.JPG w o s 2012 041.JPG w o s 2012 052.JPG
Old age and treachery will overcome youth and enthusiasm every time. #545
old age and treachery will overcome youth and enthusiam every time
AJR192
Can you PM me about the 540? Specifications, how much run time, etc, etc, and price? Thank you.
cheap-n-dirty
Hello,
This is Richard. Here are the specs on the 540.
Gm gen 6 block, Eagle rotating assembly, engine was built by Dan Naylor now in Alburn, Ca. has a 1050 holly dominator carb, Edelbrock intake, electric water pump. Canfield heads with Com cams solid roller, with roller rockers and stud gridle. Mosser oil pan. Roadster style headers.
It has about 90 1/4 mile passes and 4 3 mile runs at Bonneville. At Firebird in Idaho in a front engine dragster it ran 7.89 at 170mph. has new valve springs installed with on pressure on them ( rockers backed off). not ran in about 8 years. sfi damper.
Dan Tuttle is the owner
208-549-1500
asking $18,000
cheap-n-dirty
cheap-n-dirty
cheap-n-dirty
