A/PG 1650 rigid frame springer front vintage racer
Started by Handlebarlife, March 21, 2024, 02:58:50 PM
Handlebarlife
Single loop rigid frame
Built for larger riders, over 6 foot and 200lbs
Narrow wishbone springer, Timken roller bearing steering head with stabilizer
Leather Low profile seat with sheepskin cover
Leather Chest pad
21" square 5 spoke front wheel spool hub
16" square 5 spoke rear wheel
Aluminum 90* valve stems
Aluminum fuel tanks 1.04 gallon combined
Braided fuel lines and Aluminum fittings from JEGS
93ci or 1525cc Harley-Davidson Knucklehead engine with stroker crank
Splined sprocket shaft and Timken ball bearing support
.420" lift camshaft
70hp/85ftlbs
Magneto ignition mechanical auto-timing based on RPM
Aluminum finned magneto cap
Bull horn exhaust with torque cones
Race spec carburetor (change jets out in 90sec, remove carb in 60sec)
Master jet kit included
Billet throttle tube
Thumb operated ignition switch
Cable-pull type ignition switch
6 speed overdrive transmission
Geared for 155mph at 5000rpm
Left foot operation shifter, N1 shift drum, all gears are up
Spline mainshaft with bearing support plate
Cable-pull type clutch left hand operation
9 plate dry/wet clutch
Open primary (Cover is included and ready to install)
Kick Start only
4 piston fixed rear brake caliper right hand operation
Stainless Braided brake line
2 gallons of engine oil
One set of "V" rated tires for racing
Built in 2021, all new cases, new heads, new internals, all new parts
Vintage style Avon speedmaster tires currently mounted
Sold with MSOs and all paperwork, receipts, and bill of sale
Top notch parts from S&S cycle, Paughco, Morris, Pingel, Baker, Ledsled, Wilwood and more.
Documented "Run" times, less than 1/2 engine hour, base tuning was performed.
Engine, transmission, Clutch and Brakes all dialed in ready to run.
SOLD
I am willing to deliver within a reasonable distance or assist with shipping.
