Rear Engine Modified Roadster #54
Started by anthony young, February 03, 2025, 01:20:42 PM
anthony young
Current record holder in the C/ fuel rear modified roadster class at 231 mph. Currently has a fresh B engine to get the 230 minimum. Running an early hemi on fuel has all of the best parts. Titan Rockers Areas Pistons Brooks rods MSD ignition, etc. (inquire for more info). Chassis has a lower 4x2 rolled and is not a sectioned welded box frame. Upper frame is a rolled 2.0 inch OD, .188 wall DOM round tubing. Car has a nine-inch Ford (Curry) extreme duty rear end with a 2.47 ring and pinion. Body is a polyform 27 Ford. This car was used to set the standards for all the rear engine modified roadster classes in the rule book and was taken to numerous inspection meetings to set the headrest and parachute fairing standards. A lot of time, money and effort went into making this body. Has new rear M/T tires plus new rear spares with wheels. M/T on front with Taylor-made wheels and an extra pair of M/T on Taylor wheel.
$65,000 (can negotiate price with purchase of trailer or can be sold as a roller)
Enclosed Trailer
28-foot custom white tag trailer. Three (3) 8500 LB axles all wheels have brakes and they are electric aluminum interior. Six (6) 4-foot interior lights, 2 stainless steel fixed work benches, fire suit cabinet. 22 upper cabinets. Snap-On?s top and bottom tool boxes, pit-pal, fuel storage area. Hydraulic ram will lift the four front tires off the ground. Has extended fixed aluminum ramps and will load the lowest car. Has a 6,500 watt Honda water cooled self-starting exterior generator and is enclosed. Trailer has new ST 235-80 R 16 12 ply trailer tires on aluminum wheels. Will sell after car is sold.
$13,500 (can negotiate with purchase of car) I have reduced the car and trailer to sell, also selling a gas REMR that is posted.
Parts
Many other engines, parts, are also for sale.
Anthony Young
562-447-8673
kiwi belly tank
Sad to see but there comes a time for all of us. I know it has enough bolts in the rear axle M8!  :naughty
231 is the El Mirage record.  The Bonneville record is 256, just to be clear.
anthony young
I forgot to mention the car is in the Build diary on Oct 25 2011 page 14, you will need to scroll down to see the pics, Thanks Anthony 562 447-8673 call or text.
Skip Pipes
Anthony is a good friend and this car is a fabrication masterpiece. It?s beautiful, expertly engineered, has first class components that perform to the highest levels. It?s expertly maintained and easy to run. This car has significant upside potential and It?s and a steal at the asking price. I can?t buy it as I just built a fresh new car, but you should. Don?t spend years building when you could go straight to Bonneville.
Skip Pipes
Skip's Garage
anthony young
#54 REMR car has been reduced in price along with the trailer, i've also posted another car for sale.  thanks Anthony
