Spreadsheets for Car builds and setups
Started by Hans Blom, March 21, 2025, 05:47:29 AM
Hans Blom
Not exactly a formula but just as important...I'm going to get the 906 GMR back up and  going again and want to make a excel sheet of basically the entire car, with lists of all parts so replacements can be easily found. When cars change hands or get worked on by others, lots of info is lost so trying to get everything in lists. I figured you could have one excel file with several pages to include, Motor, Transmission/clutch, rear axle , fuel system, etc etc....So to be easy to have a quick reference to all parts of the build.
Then one could make more like:
- trip list of equipment to load in the truck n trailer
-pre-run checklist with things like tire pressure, bottle pressures, valve clearances...things one would or might check during an event
-Lists of things to take and do at the line, like helmets, switches, harness/belts, safety pins, air inlet plugs etc
Does anyone have anything they would like to share? I can make from scratch, but likely there are some good ones already out there to just fill in and modify to suit your exact car.
