Do automotive relays need shock mounting?
Started by donpearsall, April 11, 2025, 03:00:46 PM
donpearsall
How resistant to bumps and vibration are the standard block style relays? I will be using about 4-5 relays on my bike and worry that they could go intermittent with vibration.
I remember going over well over 200 mph and putting the chin of my helmet on the gas tank to get lower. The vibration scrambled my brain.
Do you rubber mount the relays or some other method, or is that not needed?
Thanks
kiwi belly tank
Use the golden rule, "if in doubt!"
floydjer
Use Harley Davidson relays ' cause ..."You know " 😂😂😂
Dakin Engineering
I've replaced HD relays
But only for corroded contacts
2008-2010 killed the wiring harness, too.
Live,learn, replace.
Turbo Sportsters since '97
floydjer
Quote from: Dakin Engineering on April 12, 2025, 04:37:14 PM
Ladies and gentlemen of the jury...I rest my case.
1leg
You could use solid state relays if you are really worried about it.
Jerry
SDRC Member since 2013
Alternate driver 832 roadster
Jack Gifford
Or- you could raid your local telephone central office for mercury-wetted magnetic reed relays. :roll:
M/T Pontiac hemi guru
