Diesel Streamliner... fuel question
Started by notfarnow, April 25, 2007, 11:27:14 AM
notfarnow
In the description of diesel streamliner class, it states that ANY FUEL MAY BE USED.
However, in the section of the rule book that talks about fuels, it states that event sponsor's fuel must be used for all record runs. Is that an exception in diesel streamliner?
Often wrong, but never in doubt.
DallasV
Only gas class records need to be event fuel sealed by the sponsor. Nitro & alky (not sure about diesel)are available by the sponsor but do not have to be purchased at the salt or tank sealed.
notfarnow
tortoise
Quote from: DallasV on April 25, 2007, 11:43:58 AMNitro & alky (not sure about diesel)are available by the sponsor but do not have to be purchased at the salt or tank sealed.
In the diesel truck class rules it states "this class must use event diesel fuel", which suggests it's available.
So do any of the diesel streamliners run nitromethane?
JackD
The immaturity of the rule reflects the frequency of the use and level of caring.
Anybody knows that the output of  compression ignition engines can vary quite a bit with various fluids. :wink:
notfarnow
Actually I just had a closer look at the rule book.
2.B
Fuels
"If the contest board establishes an 'EVENT' gas or diesel fuel, that product shall be used for record attempts at the event."
But then in the description of the car classes:
5.A.1:
"Turbochargers, superchargers and any choice of fuels are allowed in Diesel Streamliner class."
Looks to me like biodiesel would be OK in diesel streamliner, but the other diesel classes (diesel truck, for example) have to run "event" diesel if one is established.
fastesthonda_jim
Don't know specifically about what the rule book allows you to do, but I'm told that since ERC doesn't manufacture diesel they just hit the Pilot station in Wendover, fill up a drum or two and re-sell/seal it out of the trailer.
2006 SCTA High Points Champeen
2006 Dirty "2" Wrench Of The Year
Bonneville "2" Club 2003
El Mirage Dirty "2"'s 2006
Bonneville Records: G/GS, F/GS (Boy)  G/FS (Girl)
El Mirage Records: F/BFS, F/FS, F/GS, I/FS, I/GS, K/BGS
FIA Records A, II, 8
Unlimited License
300mph line qualified (305.129 best mile speed)
The older half of San Diego's Fastest Couple
2016 Man of Distinction Award
DLRA 2019 Top Speed of The Meet (309.438 Mile - 323.3 GPS)
Dean Los Angeles
I'm going to hazard a guess that nobody is prepared to test diesel for anything. Where there is an event diesel supplied it takes that problem away.
For streamliner you don't have a problem, you can run anything. The class was designed to be wide open.
For truck classes, unlimited diesel truck is also wide open on fuel (5.F.1). For the other diesel classes at El Mirage for example, there is no event diesel that I know of, so it's, ahem, wide open.
JackD
"It is a  foregone conclusion that is forgotten." :wink:
notfarnow
Quote from: Dean Los Angeles on April 25, 2007, 09:33:37 PM
Thanks! That was my interpretation as well, I just wanted to make sure I wasn't understanding it the way I WANTED to
John Nimphius
Whatever they put in those diesels, it's a crime they run so good on stuff that smells so bad!  All that black smoke doesn't look that good either.
notfarnow
Quote from: John Nimphius on April 26, 2007, 11:29:27 AM
Wait till I show up running used canola oil from a chinese restaurant. Way less smoke, and smells like a Combo #3
}{ead$hot Zod
1992 Dodge D250 Cummins running biodiesel and waste vegetable oil.
#284 ?/DT
"I don't do use drugs but my truck does"
->Stage III Meth injector.
http://frieddiesel.blogspot.com
1212FBGS
what ya gonna show up with.... send in your entry yet? pre entry is up in a few weeks
kent
As I recall, Carl Heap didn't always run straight diesel.
