spill plate dimensions
Started by Jonny Hotnuts, June 03, 2007, 05:45:46 PM
Jonny Hotnuts
My question is why do people cut the underside of their spill plates off......it may look better but I can see no dimension that says they need to be cut off......I could see someone saying that you needed to maintain a 2" distance from any angle of the spoiler.....this would still make a 12" radius from the contact point of the spoiler!
I may be out of my mind but to me the more surface area of the spill plates behind the car is the most important.....seems odd that people would chop off the underside.
jonny_hotnuts@hotmail.com
*Andres Segovia
dwarner
There were complaints about Rich Manchen's Alfa. So instead of trying to beat him there was a rule put into place that will limit the spill plate size. With the spoiler laid flat/parallel to ground your spill plate sides cannot exceed more than 8" above or below the the spoiler plate.
Jonny Hotnuts
Thanks DW.
What I should of asked is it legal to make a spill plate as I had in the pic without the under-cut that I have seen in most spill plates.
I found an example pic of a car that answered my question:
http://www.millerdesignmfg.com/119_resize.jpg
*Andres Segovia
JackD
 "So instead of trying to beat him there was a rule put into place that will limit the spill plate size."
[/quote]
I think Dan gets it. :wink:
maguromic
The shape and size of the end plate is also used for tuning of the wing.  You can increase down force and decrease drag at the same time with the shape and size of your end plate.  This helps maintain the pressure differential above and below the wing.  An important part to look at when designing your end plates is the height of the end plate to the relative span of the wing.
