Marlo Treit's Liner
Started by Freud, July 30, 2007, 08:29:06 PM
The dimples are spuds welded into the roll cage that will mount the carrier plate for the air brakes.
The area defined by the masking tape is the section that will cover the roll bars. It will be cut out
and permanently attached to the roll cage.
The third image shows the two sections that will complete the tail and are supported by the piece of
tubing from a prior foto.
PJQ
Such a quality build!
The more you look, the little things stand out, like amazing corner gussets.
And the work on the latches. And the blower arrangement. The exhaust. And the... and that... and, and, and. I'm a bit excited!
When this liner makes it to Oz, the crew will be shooing me off like an Outback fly (and they're damn persistent).
It would be a real privilege to meet the builders and check it out up close.
Question out of ignorance: would stability become an issue when air brakes like this are used at speed, or is that overcome with the weight of the vehicle?
Regards,
PJQ
Velocity Science Laboratories
PJQ
Thinking out loud attempting to answer my own question...
I guess the parachute(s) will be used at the same time as the air brake?
The air brake will radically change the flow across the body and the parachute(s) will probably need to deploy further away from the back of the car to be efficient?
Unless: the brake is used after the chutes grab, in which case, will the air brake be effective?
I guess 500+ is a long way from 200 and things would be different out there. For a non flyer type, 500+ is pretty hard to get your head around (200 ain't so hard to think about). I have imaginings of a very bouncy ride slamming an air brake on at anything over 300 (no matter what the weight or body shape).
Regards,
PJQ
Wait for the Bargains......... The ticket went down to $60. Less than half price.
What a deal.
I'll reply regarding the air brake and chutes in a day or so. I'll also be going to Humes Wednesday for more fotos.
The answer to PJQ's question regarding the air brake.
At the time the air brake was designed and machined it was considered to be the primary deployment at the end of the run.
The car is never static. Anything that seems to be an improvement is considered. In the case of the air brake, new products have been acquired that have changed the plans. An adequate supply of chutes has been acquired and they will probably be the first line in braking. These chutes will withstand a load of 10,000# at Mach 1. The car doesn't weigh that much and won't go that fast.
Testing at progressively higher speeds will determine the final pattern of use.
PJQ, that was a good question.  I hope my answer was adequate.
sockjohn
Quote from: PJQ on October 22, 2007, 08:35:00 PM
I'll second that, I sit and amazed at the quality of work.  I can't fathom the amount of man hours that will go into this before it's done, and look forward to they day I hopefully see it run!
Dr Goggles
Quote from: sockjohn on October 24, 2007, 06:47:07 PM
I think I've written this before but yes it is incredible , I can't wait to see it out here in OZ ....I'll go one better and do my utmost to make it look even better by parking our car next to it.... :-D :-D :-D...it'll be a bit like Tiny Tim jammin' with the London Philharmonic..............
I've been involved with this project since day one. I have come to a very learned conclusion.
It seems to me to be easy when you have enough tools.
Take a quick look into Hume's "tool fetish" driven operation.
Image 34: An original Frost English Wheel, 42" throat and a multitude of lower anvil wheels.
The rubber top wheels are for forming w/o stretching  the material.
Image 35: TM Tech Air Planishing hammer. In the background is the Jet Vertical Mill.
Image 29: The Bead Roller has a variety of forming wheels.
Image 28:  The drawer of hand made Flaring Dies run from 3/8" to 3" in 3/8" increments.
There is a separate set of dies below this layer that have a gradual radius for special
applications. The machinist retired when he finished this set.
The tool fetish is evident in the vise Grip department.
The attached wooden pieces allow a tight squeeze w/o the problem
of dimples in the metal. Surface finish is a priority and this helps.
He also found several "older items", that he just couldn't resist,
at a garage sale. After all, a vise is just like a camera tripod.
You use the biggest one you can carry.
Speed Limit 1000
Quote from: Freud on October 24, 2007, 09:44:42 PM
/quote]
Freud, you could give most people all the tools in the world and not 1% of them could do half as good a job, it is the artest not the tools that get the job done.
What is the percentage when we include Stainless?
Bout 50 50 I'd guess...
thanks for thinking of me, did you pee your pants again???
Just kidding of course, have a good one Freud....  :-D
Speed Limit 1000
Quote from: Stainless1 on October 25, 2007, 12:09:33 PM
Able to use half the tools and hurt yourself with the other half?
Many tools have multiple uses.
The original intent and second duty as a bottle opener.
Stainless can easily adapt to the alternative function; especially with a Vise Grip.
F
Lynchy
I'd have to vote the vise grip as one of the most useful multi-function tools ever. They can do anything.
