Marlo Treit's Liner
Started by Freud, July 30, 2007, 08:29:06 PM
Scott.....Thanks for your interest. I can tell you that the day Hume said the frame was complete,
all aligned and welded, I though to myself  Damn, It's really coming along.
The skin has taken almost 5 times as long to do as the chassis.
I guess I lost my head but in the meantime, I have learned to watch the progress
and be patient.
Thanks to all of you for your interest.
interested bystander
Hey, Freud and others, the Cistene Chapel ceiliung wasn't frescoed overnite!
5 mph in pit area (clothed)
Dr Goggles
Quote from: Freud on February 05, 2008, 01:24:28 PM
and be patient.
thanks for keeping us informed Freud, I can understand your excitement , it's a sensational piece , mind-boggling .........it'll be a real buzz if they do bring it out here 8-)
floydjer
All of the banging and clanging noise you hear is me tossing my tools in the trash after viewing this build. That is the most awe inspiring work I`ve seen in quite a while.    Jerry
The pictures show a lot, but until you see the real thing you just can't believe the craftsmanship. Everything that Hume does is art in metal. Never in a hurry but the love and pride of what he does. Marlo picked the best for the build. :-D
Brian Westerdahl
Hey Glen I'm not sure who picked who I think maybe Hume picked the project and Marlo said OK.
  Brian #7796
Brian Westerdahl
The whole bunch are great guys.  It couldn't have been a better match.  Brian #7796
floydjer
A quick question I didn`t see adressed prior. The steering, is that box operating against master cylinders that then act on slaves at the front via hyd. pressure? Very clever if it is (if not I`ll file that one away)!   Jerry
The car has hydraulic steering. :-D
Bob Drury
Hey, its only 42' long.  You'd think cables would work :-D
Bob Drury
The engineers call it fluid transfer steering.
Dynoroom
Proven to over 425 MPH, even if it's not SCTA legal...... of course Marlo's not thinking SCTA with this ride.
Bob Drury
Dyno, what a mess it would be if they made him run a shaft.  About 30 feet of 1'' cold roll and maybe 10 0r 12 u joints would probably get there.  One of the neat features Jim Hume built in the cockpit is the steering wheel/control panel pod which swings up vertical for driver ingress/egress.  That is where the hydraulics start.  Another neat feature is the split throttle pedal that Les Davenport whittled out on his cnc.  The purpose is to help control throttle speed on each motor independently or together.  I think I would need that on my sphincter..........................Bob
Bob Drury
I have just looked at the SCTA rule book for steering and they do require a "gear or link" type of steering which pretty much rules out any type of hydraulic or electronic system. But for a car as long as Marlo's it would certainly look like a "fly by wire" system would be the most appropriate. A rotary pot on the steering shaft and a small servo valve and cylinder with position feed back on the front wheel steering link. They would need a small hydraulic pump to power it but the response would be very fast and completely adjustable. I reviewed the pictures on this thread and did not see anything that looked like steering, if they are using some sort of master slave hydraulic system there could certainly be some challenges with this approach as line loss alone for a 42 foot long car could give you pretty heavy steering but as you probably don't want a real high gain (responsive) system anyway they could probably run lots of mechanical advantage ratio between the steering wheel and the master cylinder. Bleeding the air out of this system will be very important and also providing some sort of accumulator to make up for any possible small leaks in the system and keep the system "preloaded" at some pressure to keep it "tight". Having been in the hydraulics business for longer than I want to think about I will guarrentee you that they will have leaks.
If they ever need some extra dollars they could sell tours of the car for gear heads like myself, it is just to neat!! I would gladly pay to be able to spend time looking it over. I am sure that I would not be the only one!!
Bob Drury
Rex, the car has aproximately 6 to 10 degrees of steering, so the ratio or pressure to operate are almost a moot point.  It either goes straight or it doesn't go at all. The car is transported, turned, and worked on while hanging underslung from the carriage.  The carriage resembles a early 50's lumber carrier with four wheel steering and a hydraulic winch/lift system.  As with anything Marlo does, its a show piece in itself.  Hopefully he will have it on display for the next NW Reunion.....one more reason to come.  I am already working on Freud to have Dolan either as the speaker or on display with a mussle on.  I can hardly wait................. :-D
Bob Drury
