parachutes
Started by mkilger, November 30, 2007, 09:22:35 AM
mkilger
how many parachutes  can you run a a fuel/gas roadster if the car gos over 250mph ????? thanks mike
Quote from: mkilger on November 30, 2007, 09:22:35 AM
At least one and probably as many as you want unless the addition of a number across the back and the shrouding around them would be called excessive and really be about aerodynamics and not stopping the car.
c ya,
mkilger
what I mean is can I put 3 parachutes ,an extra one just in case??? and its not about aerodynamics its about getting stopped if we have to. They will have no shrouding around them. thanks Sum
1212FBGS
The rules spec 1 up to 300mph then ya need 2..... if your gonna be around 250mph and want a back up chute 2 would be good.... you need to wory about stopping at elmo buy not bonneville.... ya gonna put brakes on her?
kent
mkilger
Yes we will need to worry more about elmo too I just dont want to add one and not get the record I know the roadsters are the worst class for rules but its all in good fun and we will have 15in rotors on the rear sould be ok
There is nothing in the El Mirage proceedursa that says you can't. Almost all fast roadsters have 2 chutes. The lake bed is short on shut down area. I think Dan Warner or Russ Eyers could best answer.
interested bystander
If you had in mind putting three (or even more) chutes perched vertical across the decklid to act as a SPOILER one of the nit-pickers out there might question that as an illegal aero device- but if you feel you're gonna need that many either because of the speed you hope to attain or the weight you're trying to slow down, it's probably OK IMHOP.
5 mph in pit area (clothed)
 this video -- shows one of Strouds chutes---I have been very pleased with the way it hits and especially with the way it sets and doesnt "KITE fly" like some do--------extremely pleased the way it behaves!!!!!!!
mkilger
Sparky thats a great shot of the parachute, Do you run more than  one on your lakester? Was that run before you spun the car at sw, I was working the ERT at this years speed week I was the one who jumped  out of the truck to check on you. thanks for the info. mike
yes the next video show that run where I got side ways.
1212FBGS
if ya have more than one chute, make sure that the release levers are seperated apart enough so ya dont accedently toss the wrong chute out.....from past experience of course...
Kent
I "now" have my chutes where I can swap tubes --so that at El M I can have the LOW speed as primary the one that has a strg. wheel release!!!!
