Fire Bottle
Started by bharmon77, January 16, 2008, 10:16:26 AM
bharmon77
I bought a "Fire Bottle" brand fire bottle for my lakester from Jegs and their catalog specified it to be Halon 1211, when I recieved it it was filled with FE-36. Can anyone tell me if FE-36 is an acceptable Halon sustitute for closed cockpit cars as the rule book states?
BHarmon
1212FBGS
I think Roy Creel is the fire guy...email him at the SCTA
kent
dwarner
From the 2008 rulebook, updated fire paragraph:
3.Q   FIRE EXTINGUISHING SYSTEMS:
All cars and enclosed motorcycles shall have a minimum of one driver-controlled fire extinguishing system using a minimum of 5 lbs. of extinguishing agent designed and applied to function as driver protection.
Approved agents include Halon 1301, Halon 1211, DuPont FE36, and certain AFFF systems including Cold Fire 302, ESS Foam, Firefox Gem Foam or other Halon replacement certified by the manufacturer for use in a confined space. Dry chemical and CO2 may be used in the engine compartment only. The application and installation shall be in accord with the manufacturer's recommendations and consistent with the size and shape of the driver's compartment. The discharge rate should be designed to allow sufficient protection for the time it will take the car to stop from speed.
Dean Los Angeles
That's not surprising that you didn't get Halon. It's being phased out world wide. SFI Foundation standards no longer certify Halon. Safety Systems (Firebottle) uses FE36 in their units. Halon is still available, but the clock is ticking.
bharmon77
Thank you for the responses, I am still working with last years rule book. I will use as is!
BHarmon
