old time lake racer bike
Started by sheribuchta, January 25, 2008, 02:18:46 PM
sheribuchta
This is going to be a long build because of part supply, weather, and my other projects. So if everybody would do me a favor and try not to post so we don't stretch this out to far. Try to keep the build on the first few pages then you can post all you want. It's basically a single down tube frame with a swingarm and a pair of coil overs mounted horizontally on top frame rail. Or maybe to the top of the motor. The bike is for Eric Ross. He's tired of riding his Ducati 140 mph on a 170 record. So we are going to build him a bike that will run the number. Dave Bozzie (the son of John Bozzie,builder owner rider of the twin engine drag bike called  "the Thing" and a rider at Bonneville in the '50's) is going to build the motor and the rest is up to me. It's going to be a cross between a board track racer and a neo classic custom. Kinda weird but that's what Eric wants. So here goes...
I started building some of the parts awhile back so some of the pics are older than the rest. I don't work on the bike everyday but when I do I'll post pics. If you have any questions direct them to www.willieworld@hotmail.com.
Willie Buchta
the rear frame castings are from a harley softail swingarm
sheribuchta
#1
more pics   tubing is bent for the swingarm   1 1/8 x .120 wall  dom
sheribuchta
#2
more pics
Willie Buchta                        parts are fit together
sheribuchta
#3
more pics
Willie Buchta       parts are welded together on a jig   pieces of tubing welded to the workbench
sheribuchta
more pics
Willie Buchta
sheribuchta
#5
more pics
Willie Buchta               the swingarm bolts to the back of the transmission    the transmission is a 2000 or newer harley dyna 5 speed
sheribuchta
#6
Last of pics of the first series..
Willie Buchta     i know everything in the shop looks rusty  its either the camera or the lighting in the shop
sheribuchta
Here are some more pics of the front frame tube it goes underneath the motor where there is a cutout to clear the motor. There is some reinforcing that will tie into some other frame tubes later on. The reinforcing plate was bent in the vise with a hammer. The notch was cut in the tube on the band saw.
Willie Buchta
sheribuchta
A few more pics.
Willie Buchta
sheribuchta
Took some more pics..than took it out of the frame jig today. It still needs rear suspension and minor detail but you'll get the jest of it.
willie buchta
sheribuchta
A few more pics...
willie buchta
sheribuchta
Here are a couple of pics. We just hung the frontend on to get an idea what it will look like.
willie buchta
V8Pinto
Shane
V8 Pinto on juice
Hayabusa on the brain
Twin-Turbo F150 4x4
1212FBGS
that rear rocker cover looks like fun to get off...
kent
isiahstites
Looks good Willie............you really like those Electraglide wheels don't you?
Scott
