Frame jig
Started by sheribuchta, February 27, 2008, 04:11:44 PM
sheribuchta
the jig is up...
Willie had some free time yesterday so he finished up his jig. He already had the I beam which is 8inx8inx10ft long flat beam(Some beams have a crown). The cross members are 2x2 in. square tube. They have 2 pieces of angle iron welded on the bottom to keep them squared and centered on the beam. The top has a 1/2 in. slot milled on the top. A piece of angle iron with a hole, a bolt and a piece of flat 1/4 inch inside drilled and tapped. The angle iron on top slides in and out or turns it any angle. There are 6 crossmembers, one every two feet. This particular jig is set up for a frame that I am going to build. I probably won't start the project till May because I am loaded down with other projects right now.
See you on the dirt and on the salt.
Willie Buchta
sheribuchta
here are the pics
sheribuchta
more pics  left click on mouse to enlarge
fredvance
Willie, what is the jig for? what are you building?
sheribuchta
a streamliner  for a customer  i will post the build here    willie buchta
Bob Drury
Forget the jig, I just want the shop.  Nice to see a clean floor.  It says a lot about the craftsmanship of the owner.................. and no, I don't know him............Bob
Bob Drury
Willie---thanks for the picts---I can see some new attachments coming for my JIG---thanks for the ideas
1212FBGS
what kind of liner?
kr
sheribuchta
kent   i was in the shop this morning i turned on a band saw it was makeing a strange noise i listened to it for a while and i swear it sounded like  landracing-landracing-landracing-landracing over and over again i finally turned it off and went in the house and realized i had forgot to take my morning meds----a sidecar of course     willie buchta
bak189
O.K.....now we have 3 sidecar streamliners...and one in the works......what is this world comming to?....................................................................................
JackD
Quote from: bak189 on March 02, 2008, 02:22:38 PM
CRUTCHES 8-)
willieworld
hello all   i had some time so i finally got the frame jig painted
here is the finished project
willie buchta
willie-dpombatmir-buchta
saltfever
Thanks for posting the pics, Willie. Some very nice ideas.  The paint job looks nice.  I hate to see the jig after the project is over when all the extra tabs and gizmos have been randomly ground or welded all over it as the need arises  :-D
