so how long is the shutdown area/
Started by Carl Johansson, May 04, 2008, 07:36:32 AM
Carl Johansson
so after you go through the traps,  how much shutdown is there at Goliad?  I went to their website,  but couldn't find it anywhere.  In the supercars show shot there,  the guy says it's only 1/2 mile of shutdown,  and that does't seem right!
Carl Johansson
Carl Johansson
Auberry Ca
Quote from: Carl Johansson on May 04, 2008, 07:36:32 AM
Carl Johansson
I think Stainless told me maybe even less than that.  Stainless??
1 fast evo 2
It is a 1/2 mile or maybe a little less. It's not bad until you are really moving like over 200 unless your brakes are" not so good". I would highly rec. a parachute(if you run a car that is).
E.C.T.A. 200 MPH club
221.4 mph at Maxton sept. 08
tricktom1
it's supposed to be 1/2 mile. I've been 237 with no problem. I would not recommend that fast for a newbie though. They have a drive through before everything starts, I recommend that for sure.
TexasMile 261.5 MPH
http://www.houstonmile.com/
TheRipler
Just from rough guestimates on google earth, it's ~.5mi of good shutdown before the turnaround, and there's ~.2mi more of WWII era concrete if that's not enough. If you need more, there is a pasture. I would recommend stopping before you get to that.
Professor Weinburger sighed, knowing that without the alien mother to care for the last surviving egg of her once-proud species, the egg would surely die; still, he thought, greasing the fry-pan, it certainly was going to be an interesting breakfast.
willieworld
#5
http://www.airnav.com/airport/7T3            looks like they have 2 runways 8000 ft each ------            willie buchta
willie-dpombatmir-buchta
The Race runway is a Standard Navy "bounce strip, to practice carrier landings" ---1000' of concrete on each end with 7000' of very smooth asphalt in between. the problem is you dont start at the outer edge of the concrete----have only seen pictures of start line.  But I checked it out in '99 when Govt. just turned it over to the county. Skip and I were looking for a test strip.
Stainless Two
It can get a little hairy on weak brakes.  I was getting high 180s and had to engine brake hard and full rear brake at the end for the lack of the front disks and rotors.  I tested the overrun area once as well :)
Standard brakes should not have any problems.
Look at my new RED HAT!!!!
#278 1000CC APS-G 208.959MPH record
209.093 mph best time
pit bitch to #1000 Bockscar
Proud to be a Texan!  in San Antonio
willieworld
the faa says its 8000 ft-and on each end is 1000 ft of concrete leaving 6000 ft of pavement-----------------http://www.airnav.com/airport/7T3  ------------willie buchta
Willie---who you gona believe---the FAA of my senior memory!!!!!!!!!!  LOL thanks for setting the record straight---there is a 1000' of semi-packed gravel beyond the concrete.
