Hypothetical steam rocket land speed car
Started by Ratliff, June 01, 2008, 06:37:22 PM
Ratliff
Performance spreadsheet showed potential top speed of over 950 mph with mile average of over 880 mph.
Ratliff
Discussion of design issues (pages 1 and 2)
Ratliff
Discussion of design issues (page 3)
Ratliff
Discussion of design issues (page 4)
Dynoroom
As Dolan would say..............
Hypothetrical cars set hypothetrical records.
Geesh I can't believe I just did that..........
I don't think I'd want to be anywhere near a boiler that produced enough steam to propel ANYTHING to 880 mph.
Ratliff
Quote from: Milwaukee Midget on June 01, 2008, 09:00:44 PM
No boilers involved in the car itself. The tanks in the car would just be storage tanks. The water would be heated externally in a separate boiler then pumped into the car. Maximum operating pressures would be around 400 psi.
Rick Byrnes
Quote from: Dynoroom on June 01, 2008, 08:55:05 PM
AWWWW   you miss him too
Rick
Ratliff
Yeah, just like that hypothetical 500 mph record Doug Herbert is going to set.
Ratliff
http://www.steamcar.co.uk/
If you want to see a steam car that not only has boilers but will be operating at much higher pressures than a steam rocket car, there will be one at this year's Speedweek.
Blue
The 21% empty weight fraction and the attending ~10% structural fraction for a 1500 to 2000 psf vehicle are more than a factor of 2 away from being rational.
This is a difficulty that I have run into with a lot of the people "designing" ALSR cars.  Stresses are factors of 4 to 6 greater than any wheel driven car, 10X for Mach 2.  Think about that factor of 10 very carefully.  The design database of supersonic-at-sea-level capable aircraft and missiles provides plenty of structural weight and design guidance that simply cannot be ignored.
If anyone wants to pencil out something like this, a 1000 mph FIA record requires a 35 to 40% structural mass fraction with advanced materials, straight load paths, and good structural design.  Poor design or heavy materials can raise this to 60 to 75%.  Note that the "structural" mass fraction does not include the engine.
For reference, the structural fraction of our current project is nearly 60% due to the use of mild steel and a far-from-optimum structural layout.  Thrust SSC was about 50%.  10% is irrational. :-o
Ratliff
#11
Quote from: Blue on June 02, 2008, 03:47:02 PM
Craig Farnsworth, brother of Blue Flame co-builder Pete Farnsworth, is a missile engineer.
Steam rockets operate in the 250 to 400 psi range.
When one DOES THE MATH and examines various tank configurations, a 4,000 pound empty weight car with sufficient volume to hold 13,000 pounds of water may very well be feasible.
Ratliff
Ratliff
Ratliff
