0 Members and 24 Guests are viewing this topic.
Chris, Great job on the run! :cheers:
#736
Thanks for all the encouragement and ribbing.  I'm finally confident that I'm heading in the right direction.
As was my suspicion, up until now, I simply had no place to find out when the engine came on the cam.  It appears to up there a ways.  Unfortunately, I didn't take particularly good notes, but I do need to launch it above 4500 or 5k to get it over the hump, and it will just stumble until the momentum of the air through the head starts to hit the sweet spot.
I've got two thoughts in mind to try to build up the lower end of the powerband.  1st off, I'm thinking of going with a slightly smaller set of venturis in the carb, in hopes that the flow rate will pick up a bit at a lower RPM.  I don't think I've got any restriction of consequence on the intake side, and getting the intake speed up should be somewhat helpful.
Additionally, a longer manifold might help.  I've seen some A-Series Weber manifolds as long as 7", and while that would be impractical in my application, I've got a 4" Maniflow manifold I can cut the flanges off of and have a manifold welded up that will maximize the available space.
What I did came away with, and what has re energized my efforts, is that indeed, the short stroke, way-too-big rod-to-stroke ratio does indeed work.
I need to get a bit of dyno time in.  I want to get a true baseline - something other than the seat of my pants.
A  Confirm and maximize the timing
B  See if I can utilize and/or maximize the knock sensor to my advantage, which I simply bypassed at Maxton
C  Change out the venturis
That would be a solid day on the dyno - not cheap, but cheaper than a trip out west.
And I've GOT to get this thing aligned - it was like a water strider, skipping across a pond.
Quote from: Freud on October 31, 2011, 10:44:31 PM
I'm glad you are home, Midget.
But it also felt good to participate, didn't it?
Freud, seriously, Wednesday night. after packing up, I looked at the Midget and the trailer, and almost talked myself into just spectating - that's how unsure I was.  I came within a gnat's Acura of loading up the trunk of the MGB, and just calling it a vacation.
But once I was going through Rookie O, and had the car in line, I realised, and I think for the first time, that this is not spectator sport.
So yes, my friend, it felt REALLY good to participate, and more importantly, to do so at a level that I don't have to make any apologies for or jokes about.
Yeah, Glenn, it really, really did.
gkabbt
Chris,
Really good meeting / talking with you at Maxton (I'm the guy with the Rampage) and really glad you and Mrs. Midget made the long trek to Maxton.
It looks like you are slowly but surely getting things sorted out. Now comes plenty of time during the off season to get ready for Wilmington in April. See you there and I hope I have my truck there as well.
Gregg
P.S.
All I can say is DANG that thing is loud....but music to my ears.
Graham in Aus
 :-D :-D
Congrats Chris, you must have a great feeling of satisfaction, I can't imagine what you must have felt the first time it 'cleared it's throat' and came on the cam....   :-D :-D
All the things you refer to sound spot on to me, smaller venturis wil certainly help the 'signal' for the jetting, now you've run it in a bit, the dyno awaits!
What next?? The salt next year? That record looks a very satisfactory target!
wisdonm
Good try Chris.
Give Dick a call at MG Ltd. Most people are unaware that he makes custom intake manifolds.
Has a checkered past.
RidgeRunner
Chris,
     Get the alignment confirmed for sure but that could very well have been considerably less that 100% of the problems you had.  A couple of drivers whose opinions I value mentioned their rigs [both relatively small and light] doing your "water bug dance" due to the wind on Sat.
#741
Quote from: wisdonm on November 02, 2011, 07:32:49 PM
Good try Chris.
Don, thanks for that one.  I knew he did some custom MGB racing parts, and mostly SU manifolds, but I've got the flanges for a Weber.  The manifolds on both the A and B blocks are nothing more than pipes, but I'm sure it would be a better bet to have MG Limited do the work than just having a welder with no insight to these engines stitching it up.
Last time I talked to him, he was starting on an MGA to race - have you seen it?  The work coming out of his shop is impeccable.
Quote from: RidgeRunner on November 02, 2011, 08:59:00 PM
Chris,
It was a bit breezy on Saturday.
Ed, was everything okay when you got home?  Good meeting you.
Quote from: Milwaukee Midget on November 02, 2011, 04:56:28 PM
Heading in the right direction?.....search "Renee Geyer ,Heading in the right direction 1976" you'll love it.
Where does a push car figure into this? A push to 30mph will have you at the 1/2nd shift wouldn't it? Once you've got some dyno done you'll have a better idea but isn't tinkering with the bottom end gonna tax the top end?
Gee I wish I'd seen it.
RidgeRunner
Chris,
     Left at 4:15 am Sun, chased the storm on relatively dry roads all the way [840 mi], and arrived home 6:20pm.  Bride had hired a guy with a plow to make a couple passes to open up the driveway that afternoon [we got over 20"] so I wouldn't have to deal with it when I got home, very pleasantly surprised when I arrived. I finished cleaning up with the tractor Tues morn with no problems.  Big ice storm a couple of years ago had taken down all the weak stuff, snow was light and fluffy so they hadn't lost power.  Different story at the lower elevations all around us, less but heavier snow took down a lot of trees, some sections of MA and CT still without power.
    Looking forward to seeing you again at Wilmington in the spring.
[/quote]
Chris, I think Dr. Goggles is right- push car, and concentrate on the top end- bottom end doesn't matter!
Captthundarr
Chris, it was great meeting you and Mrs. Midget, The car is a cool piece of work and to quote you " you got a race car now" now to sort it out. 91 mph and change ain't too shaby my friend. Hope to see you in Wilmington.
Frank
Hey Chris, if your exhaust note's annoying and by several accounts it is,  you're probably on the right track. :evil: :evil: :-D
Quote from: Peter Jack on November 03, 2011, 06:19:18 AM
It's like being in a band with a really loud banjo player.  :-D
Captthundarr
The exhaust note is only annoying during drivers meetings and such, otherwise it's music to the ears. :-D
