Quote from: Speed Limit 1000 on March 25, 2016, 08:59:36 AM
I have 4 1980 G1 Kaws and a '82 1100 GPZ  with factory FI
More Kaws than a Wisconsin Dairy farm!  :cheers:
Quote from: Milwaukee Midget on March 25, 2016, 12:06:23 PM
More Kaw poop too?
WOODY@DDLLC
Beware!  :-o :-o :-o
he has thinned the herd... used to be about a dozen of them  :cheers:
midget,
Flatout advises that the head gaskets are finished and ready to be shipped.
I'll have them sent to the ranch.
OBOY!!  Parts!!
midget,
Injectors arrived on Saturday.    They fit into the holes in the throttle bodies, but might not project far enough into the T/B.   Some pics later.
I've got a plan for a flow bench adaptor, and I am assembling the bits.     I will keep you informed on the progress for Thursday.
Workingflatoutboy
midget,
If you do come down on Thursday, can you bring the original injection manifold?   I want to see how far the injectors project into the runners.
I have some Cosworth/Lucas mechanical injection bits we can use to compare.   I know they work OK for bhp.
jacksoni
Quote from: fordboy628 on March 29, 2016, 03:43:19 AM
midget,
Workingflatoutboy
Do you want the tip actually protruding into the airflow, or just at the edge of the wall? There are of course, zillions of injectors out there, some with long tips, just a matter of seeing if right size and shape is available. I know Kinsler does some modifications of injectors, probably others as well. Can a tip "extender" be added?
G/GCC- 194.580 2025
Or . . .
Mark, is it possible to machine the bosses down to place the injector at a proper height?  :roll:
Quote from: Milwaukee Midget on March 29, 2016, 06:14:34 AM
Or . . .
Unknown @ this point.    I am uncertain of how the injector bosses are held in the throttle bodies.     Maybe they can be pressed out and machined.   Perhaps they can be pressed out and a new and different injector boss substituted.
My thoughts on all of this are on hold until we have the flow numbers.    And unless something is royally screwed up, they should flow OK.
Lucked out on the flow fixture idea.    A 1.25" plumbing repair band clamp has the perfect ID to connect the throttle bodies to the stub pipe flow test fixture.
Sometimes it's just better to be lucky rather than good.
Aaahh, who am I kidding!!    If I had any luck at all, I'd use it to be a "super-villain".     Way more fun than a "super-hero".
Besides, heroes get taken for granted . . . . . .
        and there, I am going to stop.
Flowfixturemakin'boy
jacksoni
Or . . .
This is of course an option. I considered that. The issue may become depending on exactly how the fuel rail is positioned and fixed in place, if moving the injector down (there is some leeway of course, depends on how much) if the fuel rail then interferes with something else or doesn't attach correctly. May then require custom fuel rail. As in fixing one problem causes another.  And I am basing these observations on the ebay photo of the TB assembly. Having parts in hand and measurements makes the answer easy ,of course :)
G/GCC- 194.580 2025
Hi, Jack -
I've already conceded the custom fuel rail approach - the 88 mm centerlines dictate that, and the stock fuel rail is made of some sort of plastic reinforced - or shall I say "rein-farced" - tubing.
Besides, it doesn't look "racey".
If I'm going to go through the headache of stuffing a fuel injected DOHC 16V Eurotrash motor under the bonnet, it damned well better look "racey" . . .  :wink:
jacksoni
Quote from: Milwaukee Midget on March 29, 2016, 07:12:04 AM
Hi, Jack -
Well of course!! :cheers:
G/GCC- 194.580 2025
