Tubing Notchers and Benders??
Started by isiahstites, July 04, 2008, 02:52:16 PM
isiahstites
What are you guys using for notchers? I am planning on building a new bike and am going to need a good bender and a notcher first. The notcher I have now is a POS. Are there any links you guys have to a notcher I could build rather than buy? Show me what you guys are using for notchers and benders. I will probably build a bender and buy a notcher unless someone has a good plan for a notcher.
Scott
doug odom
I have used the www.lowbucktools.com notcher for many years with good results. I do use the 4 inch grinder after I notch the tubing to get the best fit. I have built about 30 race cars with this notcher and never had to replace anything.
Doug Odom in big ditch
John Burk
Scott
The radiused end of a tube turned 90 degrees is 2 straight cuts . I do mine with my Portaband and dress with a 4" grinder .
isiahstites
Thanks for the link and suggestions. I have been using my cheap notcher and then dressing the notches up with a die grinder if needed. I want something that is going to make a precision notch for a very good fit. The low buck notcher I have seen before, I am not sure how it works, does it just cut the tube instead of drilling on it with a holesaw?? Is it kinda like a punch?
Scott
hotschue
Nice, easy and clean cuts.....Harbor Freight $50.....Bi-metal saws Home Depot... chrome moly cage....perfect fit every time..I was considering buying a high dollar notcher, glad I didn't.
221.559 D/CGC '03
182.144 G/GMS 2019
4-barrel Mike
Hotschue:
This one?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42324
Make perfect joints for clean secure welds. Use with your electric drill or drill press. Precision settings from 0° to 60° in 1° increments.
Use with 1/2'' chuck
Accepts 1/2'' and 5/8'' threaded arbor hole saws
2'' pipe capacity
Requires 14'' clearance between chuck and table
Adjustable mounting bracket
All steel frame
isiahstites
Thats the one I have and it has all but expired.
Scott
interested bystander
The Dave Williams Low Buck is a different breed from the jig-a-joint type notchers.Noneof those IMHOP-and I've used three or four - are rigid enough structurally for long  term use.
Plenty OK for a few builds, though.
The Low Buck is more robust but doesn't do angles easily- I think the one I used in the late '70s might have been the prototype and Dave might have improved it by now.Dave had as big a market with corral builders as he did racers in those days. Norco, Ca IS horse country!
5 mph in pit area (clothed)
hotschue
Mike, thats the one.  I also had tohad to cut a larger tube than the unit is designed for.  The shank mount is bolted on and I put a shim washer under the mount to center the cutter.  Really easy to work with, although having a drill press helped keep everything steady.  One cutter head cut all of the fish mouths pictured.
221.559 D/CGC '03
182.144 G/GMS 2019
Grant Borman
I have been using the JDsquared heavy duty tubing notcher and am a very happy customer.  When used with Starret hole saws you get a very precise combo.   If you keep the Starret holesaw lubed up it will last for many cuts in chromoly.
I also use a JDsquared model 3 bender at my personal shop an i enjoy it alot more than the old hosfeld (sp) we used at the chassis shop i worked at.  Is nice and sturdy and has an excellent fit and finish.
Cheers,
Grant B.
p.s. I have used that harbor freight notcher and i can't say i was very happy with it at all.  Had alot of slop in it and i wonder if it would even last through one chromoly cage.
hotschue
Just a pic in use.  Lube everything, moderate to lite pressure on cutter,  takes about 30-45 sec. to make cut.
221.559 D/CGC '03
182.144 G/GMS 2019
isiahstites
Quote from: hotschue on July 04, 2008, 07:50:13 PM
I use mine in a drill press as well and I to had to add a washer to the unit to center the cutter. Don't get me wrong it worked, but it just wasn't to my liking all that much, I felt like I was spending unecessary time with the unit to get it to work properly. Then I started feeling well I got what I paid for.
Scott
I bought a Harbor Freight tubing notcher and it works OK with good quality bi- metal hole saws. I use DeWalt saws but others are probably just as good. It isn't a high quality tool but I only need to make enough cuts to build my roll cage. Like another user I had to put washers under the three tube bolts fastening the tube holder to get it lined up correctly. Crummy but cheap-- two stars.
floydjer
..Probably belongs in "How To" but, I use the hole saw to cut a "donut" out of a sponge and leave it in the  saw. Soak them in oil and you have an auto-lube .    Jerry :-)
Dave Cox
I used a "Joint-Jigger" for several cars, it worked very well compared to some of the cheaper copies. I finally stepped up to this machine:
http://www.pro-tools.com/emn510.htm
I don't know if it's worth the extra initial cost, but it sure works nice.....
