More lakester build pages are up.....
Started by Sumner, July 21, 2008, 07:13:09 AM
Well I added some more pages of what I've been doing the past 45 days or so and still have more to add........maybe tonight.
I had to rework the stock air box or what ever you call it....
http://purplesagetradingpost.com/sumner/bvillecar-3/construction%20page-112.html
I got most of the rest of my safety equipment and tried it out.....
http://purplesagetradingpost.com/sumner/bvillecar-3/construction%20page-113.html
I got the firewall started on this page...............
http://purplesagetradingpost.com/sumner/bvillecar-3/construction%20page-114.html
.......................... and finished most of it.................
................. on this page..............
http://purplesagetradingpost.com/sumner/bvillecar-3/construction%20page-115.html
This page starts the build of the Air Intake/Exhaust/Tail................
http://purplesagetradingpost.com/sumner/bvillecar-3/construction%20page-116.html
and it continues..............
http://purplesagetradingpost.com/sumner/bvillecar-3/construction%20page-117.html
.............. and .............
............. more on this page ..............
http://purplesagetradingpost.com/sumner/bvillecar-3/construction%20page-118.html
........... and that is all for now that I've gotten posted.  I'll try and see if I can finish posting about the Air Intake/Exhaust/Tail tonight if I have time.
Have to go get more steel and start on the body today,
Sum, looking good.  When you put your inner cockpit liner in there won't be as much elbow room...
Are you bringing it to speedweek for inspection or one of the later meets.  Looking forward to your runs, let me know if you need pit crew help.
Quote from: Stainless1 on July 21, 2008, 07:30:46 AM
Hi, there won't be inner liner where the elbows are as that will be plated on the outside with .120 wall plate, which I've been told will be ok.  The plate will go from the upper frame rail to the lower.  Did you take a look at the air box page??  Do you think what I did is OK and do you think I'll melt it down??
I doubt it will be at speed week since I would need to then take two vehicles and I just can't see an extra $300-$400 in gas to get it inspected.  I wanted to though, so will keep that option open.  I'm still a little hopeful about WOS or WF might be a better chance if it happens.  If you are at either of those and are available I sure might need some help as right now the crew for those meets would be me, I and myself......well maybe the dog also :roll:.
The main things to still do on the mechanics is the electrical, hook up the rear brake (make handle and linkage to master cylinder) and install fire bottles.  The really big thing is the body.  I'm starting on the framework for it today.  The other biggie is painting and powder coating everything before it sees the salt.
John wants me to fire the motor, but I'll leave it to last.  I told him that if I fired it now and found out something was wrong with it that it would be a big let down and I might slow down   :cry:.  I think it will also be easier to run the wiring after the body and bracing and everything else is done.
Keep helping Max along and see you in not that many weeks,
Sum, read 3.D.3 several more times then get a professional opinion  :|
The air box may not work quite as well as designed, they are already a flow and volume compromise to fit the bike.  I would think exhaust wrap and your metal pipe shield with a 1/4 air gap on each side if possible would keep the plastic safe, use the one you made if it doesn't.  Should I bring an extra to Speedweek?  or do you not have that much room?  Exhaust wrap shields a lot of heat and keeps it in the pipes.  I don't recommend the coatings in a closed car, tried them, not only wasted more than a $150, melted wiring, Morse cable, blistered paint and killed by melting the shift kill electronics box a foot away.  I would invest in a big roll of Ebay exhaust wrap.
The motor needs ram air, the air box does not need drain holes at Bonneville, have a good one, now I gotta go our and work on my bike a little, about a weeks work left on it... hope to be done in 2  :roll:
