Tape
Started by fredvance, July 29, 2008, 10:24:18 AM
fredvance
What kind of tape do you m/c guys use on your headlight and turn signal lenses? Also do you have to keep the tape on the lens or can it go on the fairing at all?
Duct tape is probably the most common, followed closely by the misspelled duck tape.  A good-quality transparent tape (i.e. Scotch package sealing tape) will work, too.  There's no penalty for having the stuff go beyond the border of the glass -- unless the style cops are on duty.
Whatever tape you use will likely leave some residue on the surface, especially because of the heat making the sticky stuff extra sticky.  Consider cleaning it off as soon as you can after the event.  Do this on all the tape -- headlight, sealing the seams of the bodywork, holding the video camera to the seat, whatever.
thundersalt
3M clear bra material works well
916 REMR
El Mirage 200 MPH Club
There is a product named GOOF OFF and most big box hardware stores have it. Great stuff for removing sticky stuff.
4-barrel Mike
DahMurf
Quote from: 4-barrel Mike on July 29, 2008, 11:08:05 AM
Quote from: Seldom Seen Slim on July 29, 2008, 10:31:22 AM
http://www.duckproducts.com/
   :evil:  :-D
I use ducT tape on some things;
But we've found at Maxton that the blue painters tape stays on well over 200mph and comes off of the bike much easier without leaving the sticky goo. Has anyone at Bonneville used the painters tape? Does it hold up ok out there?
Deb
fredvance
I was wondering about that blue masking tape, since my bike is blue, well you know. :-D
DUCT tape it is, except when it's called "Racer's Tape" or as we called it in one of my past professions, "Missile Tape"-- but that was olive drab.  :-)
Regards, Neil   Tucson, AZ
I use the blue tape all around the edge of the carpet in the truck and it sticks to the carpet and door sill and plastic in the center consol. I then tape down the rubber mats to the tape with more blue tape over lapping as I do it. It's pretty water proof as well, it takes a little time. Make sure you  clean the plastic sill with thinner so It stick,
Sticky-stuff remover:  There's also "Goo-Gone", available in many stores.  And then there's a 3M product, sold in auto parts/paint stores, for adhesive removal.  It's pretty much like a Goo-gone product except much more volatile (use in well-ventilated areas!!).  I use a quart every two or three years for removing old stickers on the truck and bikes.  And yes,s the 3M product works on years-old tape residue.  I apply a dampened rag and hold it on the residue for a few minutes, then start working on the stuff with more liquid, more rag, more elbow grease.
As for painter's tape -- I haven't used it, but I've seen it lots of times and have every expectation that it's just dandy -- and probably just as available as duct tape or duck tape.
Jonny Hotnuts
#10
The best product for goo removal is hands down 3ms adhesive remover.
It is 100% natural and smells great....it is even safe for food contact.
I discovered this stuff cleaning contact cement off of the roller bearings from the laminate trimmers used to make counter tops I occasionally have to build.
I now use this stuff for all types of glues, markers and road tar whatnot.
A superior product can not be beaten.
If you get a chance you should try this stuff!
If you want some style points they make a chrome metal tape used for higher temp HVAC.
This tape looks really cool and with careful trimming will make it look like your headlight is chrome.
Available at the domeheapo
jonny_hotnuts@hotmail.com
*Andres Segovia
Jonny Hotnuts
Oops I just realized that SSS mentioned the 3M adhesive remover as well.....
I thought I was the only one that knew about this stuff!!!
*Andres Segovia
Super Kaz
Quote from: DahMurf on July 29, 2008, 11:20:40 AM
   :evil:  :-D
Deb
"SKR'S Green" Painter's Tape is good for 10 Extra HP , and Matches my Leather's :evil:! Home Depot or Lowes I for got where I got it,but it leaves my body work clean and shinny 8-)!
fredvance
I guess I will go for the blue, bikes blue , leathers are white and blue. I know the fashion police will be lurking on the salt, they are everywhere!! 8-)
thundersalt
I use lacquer thinner her at the shop, but I'm always in a hurry. We do a lot of decals on rv's. A good trick is to soften up the adhesive with the chemical of your choice and scrape it off with a plastic bondo spreader. Saves on rags and the snotty goo doesn't get all over you hands.
916 REMR
