Draft load list for Bonneville
Started by hotrod, July 30, 2008, 02:10:08 PM
hotrod
The following is a load list for Bonneville I have been working on for some time. It is a dream sheet as if I had unlimited space and funds. My intent was to make a master list that could be whittled down by dropping things off the list. I used to work in emergency planning so it is organized by function or category so you can add things in each category according to what your car needs, and it gives a logical place to look for things as you massage and modify the list to suit your needs.
And no I don't have all this crap or the semi it would take to haul it! ;)
Equipment Load List / check off list
original draft 2006 (last edited 7/31/08 01:45)
Personal needs
Toilet paper
hand lotion
hand cleaner
sun screen
chapstick
hat
sunglasses
drinking water
Small backpack
Binoculars
digital camera w/ supplies
video camera
ear plugs/ear muffs
munchies
folding chair
shelter
Sleeping mat
often left behind things like driving shoes, helmets, competition licenses, certain tools, vehicle log, credit cards and cash, etc.
Cooler
white Cotton terry towels to drape cooler (desert cooler by wet towels)
Ice
water bottles
First aid supplies
eye drops
vaseline
new skin
H2O2 (hydrogen peroxide)
bandaids
Vehicle registration information
Emergency contact info phone numbers for all crew
Key phone numbers for sponsors/key suppliers
Registration packet with all essential info
Maps
Cell phone with spare batteries and charger
Drivers license
proof of insurance
registration documents
car log book (tech inspection)
Car build book (all part numbers and settings and specifications)
Pictures of car and all equipment
Pit setup - Infrastructure
Safety
pit Fire extinguisher
Welders Fire blanket
Garden sprayer water filled (engine cooling and fire)
(3) 5 gal Jerry cans for water
Spare cockpit fire extinguisher
Spare fire bottle
Shelter
canopy (sun)
ground cover
Roll 3 mil black construction plastic
large blue tarps
deck screws and washers for ground cover hold down
battery operated drill for setting screws
supports to get car up off of salt if heavy rains/wind blown water cause flooding
General purpose:
Bungee cords
nylon tie down straps
Jumper cables
Tow strap
pair of chains with jam hooks
(2) screw shackels
Crow bar
sledge hammer
3# hammer
wonderbar style pry bar
rocker head pry bar
tapered pin punch large
tapered pin punch small
brass drift
lead hammer
Pit service equipment:
(4) jack stands (base pads to protect tarp ground cover)
(2)drive on ramps
wheel chocks
assorted wood blocks
   4 (4x6 garden timber blocks)
   6 (2x4)
   8 (2x12 x 2 ft)
Under car work mats ( 2x4 and 3x3 sheets of masonite)
hydraulic floor jack (metal load spreader plates for under wheels)
pair of hydraulic bottle jacks
Engine hoist A frame and come-a-long, chain fall or what ever suits your needs
Folding table for light duty work
Knock down bench for vice etc.(heavy duty ballasted bench  Bolts to stand on work base of heavy plywood)
Engine stand
lug wrench
long 1/2 drive breaker bar
Rechargable electric impact wrench
Hand impact wrench (twist and hammer style)
stud remover cam socket
Kneeling pads
mechanics gloves
mechanics heat protective sleeves
"asbestos" gloves (heavy weight welders gauntlet gloves alternative)
Mechanics Thermotec Aluminized Heat Barrier blanket   PN#14001  40" X 36" with eyelets and short wire loops to hold it in place
lights
large handheld trouble light (AA battery flourescent)
small hand held trouble light (AA battery flourescent)
flash light Large 3 D cell
flash light small 2 AA cell
spare batteries
Pit power and communications
portable generator
solar panel charger 12V
small air compressor w/tank
Car battery charger
FM Radio
CB radio
Fluid handling
Oil drain pans (Tupperware dish pans (17"x14"x6" -- 4.73 gal --  3ea )
small Plastic storage containers with snap top lids (14"x 10" x 7")
funnels (long reach fuel, long reach flexible for transmission, small general purpose)
5 gal fuel cans
Spare coolant Jugs
Spare water for WI system
Waste liquid removal cans 5 gallons
   Waste oils
   Waste coolant
bags kitty liter (spill control, floor dry etc) also (fire suppression)
Sealable containers for old oil, coolant carry out your own waste oil  (plastic jerry cans etc.)
Tool boxes (load list in separate doc)
Meteorological equipment
weather station
thermometer
sling psycometer
humidity
wind gauge
Reference materials
List of key torque values for fasteners
List of key parts and part numbers
Pre race car check list ( prior to departure)
pre race car check list ( pit prep final checks)
Auto repair manuals
Factory service manuals
Chiltons manual
Pictures of all lines and wiring with labels
Tech Reference book, Auto math formulas with worked examples
calculator
note pad to log data and conditions
rule book
Spare parts list
Ignition system
Spark plugs 4 sets,
2 sets normal heat range
one set +1 colder
one set -1 hot
ignition parts, (coils, spark plug wires etc.)
Spare ECU
Electrical
spare 12 V car battery
spare battery cables
spare fuses (add list of sizes in ref materials)
wire sheathing (wire loom tubing)
Zip ties
   large
   med
   small
Spare battery cut off switch
Spare battery post lug for repairing battery cable
Crimp terminals and crimp pliers kit
shrink tubing
soldering gun (AC)
rosin core solder
solder flux
small prep brush (stainless steel tooth brush size)
Heat shield/protection
Aluminum foil tape
3M™ Fire Barrier Moldable Putty+ Pads (3M Id : 98-0400-5399-7)
Thermo Shield  Tape 1.5"x15' roll-  PN# 14002
Thermotec  THERMO-SLEEVE
PART NUMBER   DESCRIPTION
14005      3 ft. 1/4" - 1/2"
14010      3 ft. 5/8 - 1"
14015      3 ft. 1-1/8" - 1 1/2"
14020      3 ft. 1-5/8" - 2"
14025      3 ft. 2-1/8" - 2 1/2"
roll header wrap tape
aluminum foil (HD)
Spare LCD thermometers
Hard parts
Major component spares
spare short block (may need more than one for mulitiple class attempts)
spare cylinder heads
spare transmission
spare clutch and flywheel assy
spare rear differential
spare hood
spare radiator
spare minor components
engine:
1 set of pistons, and rings
1 set rod and main bearings
set of piston rings
spare connecting rod and wrist pin
spare wrist pin lock rings
Spare valve spring
spare valve spring retainers
spare valves (one cylinder set)
Belts and seals
V belts
cam drive belts
front  crank shaft seal
rear main seal engine.
Spare crankshaft pulley
Spare cam belt idler
Main shaft seal transmission (front)
Tail shaft seal transmission (rear)
Axle seals front transmission
spare motor mounts
spare tranny mount
spare engine oil drain plug (standard)
spare oil drain plug self tapping
spare oil pan
Spare drain plug transmission
Spare drain plug differential
spare U-joints
spare axles front
spare axles rear
Spare hood pins, and safety pins
Spare NASCAR roof rails
Spare windshield safety tabs
Accessories engine:
Spare alternator
Spare starter motor
Spare throttle cable
Spare throttle return springs
gaskets / hose
set of exhaust gaskets
set head gaskets
set intake manifold gaskets
set of spare gaskets unique to your setup
oil pan gasket
valve cover gaskets
front and rear main seals
fuel injector O-rings
spare fuel injector
spare fuel line hose
spare radiator hose
spare vacuum hose
Engine Cooling system
spare radiator cap
spare radiator hoses
hose clamps
water pump
over flow bottle and hose
Spare radiator fans
Spare radiator fan relay
radiator stop leak
Engine Oil cooler system
spare oil cooler core (engine)
spare forced air fan for oil cooler
Manual Transmission and clutch
Spare clutch disk
spare throwout bearing
Spare flywheel
clutch alignment tool
spare clutch fork and clutch return spring
Rebuild kit for hydraulic clutch
fitting and hose for clutch hydraulics
Spare transmission lube cooler core, pump and hose
Automatic transmission
Spare oil pan
spare gasket set
spare oil filter
Spare ATF
Oil cooler and hose repair parts
seals and tail shaft bearings etc.
Spare torque converter ( normal and different stall )
Tranny blanket scatter shield
Intercooler heat managment:
air to air intercoolers:
Forced air fans
FMIC water spray pump
FMIC water spray nozzles
FMIC water spray solenoid
FMIC water spray boost pressure trigger switch
liquid to air intercoolers:
spare cap for tank
spare gasket for tank cap
spare valves / fittings for coolant lines
Container to fill and drain cooler contents
Lubrication
Spare oil pump
3 oil filters
Case engine oil
Transmission lube
differential lube
wheel bearing grease
fuel supply
fuel line
fuel line clamps
spare fuel pump
Fuel filter elements
AN repair seals
wheel bearings and seals
front wheel bearings and seals
rear wheel bearings and seals
Brake system
Brake fluid (1 qt)
spare brake lines
spare brake pads
spare bleeder fitting
spare brake caliper
spare clips and springs
Suspension / Wheels and tires
Spare lug nuts and washers.
Spare wheel and tire (mounted)
Spare valve stems and valve cores
Spare valve stem caps
Spare wheel studs
Spare springs (raise and lower car)
spring rubbers
spring snubbers to limit front end rise
Miscellaneous parts
metal stock ( 1/8 x 1 inch steel strap)
flat plumbers strap
roll of sheet metal (aluminum flashing)
bamboo skewers ( small applicator, stirring sticks)
tongue depressors
Fasteners:
Assorted nuts, bolts and washers
sheet metal screws
dutz fasteners
fastener safety supplies:
cotter pins
lock washers
safety wire supplies kit:
spools of safety wire
safety wire pliers
locking needle nose vice grips
small side cutters
bandaids
Parachute related components:
Spares for chutes, tethers and attachment hardware
Aerodynamic aids
Grill block off plates, pre-cut with screws
Air dam materials.
alternate spoilers, with install kit of required fasteners
wickerbills
Aero-tape (racer tape to block seams)
car wax
spray bottle to clean car surface
windex for windows
cleaning rags
Ballast material with bolts and attachment hardware
Tape for Photo reference marks for at speed photos
Intake system
Air filter
spare FMIC tube couplers
spare T clamps for intercooler hose
Exhaust system
Spare studs / bolts and lock nuts
   cylinder head flange
   up-pipe
   Turbo
   down-pipe
Spare EGT probe and gauge
spare exhaust gaskets from cylinder head to end
tube anti-seize compound
Turbo equipment
Spare BOV
Spare BOV hose
Spare waste gate actuator and bracket/rod
hose for waste gate actuator
Spare boost controller
Spare turbocharger
Turbo heat shielding supplies
TEC heat blanket
Leather punch
lacing wire
Cooling and oil lines with banjo bolts (pre-assembled)
Crankcase vacuum system:
Spare pump
Spare air oil separator
Spare crankcase pressure/vacuum gauge
Engine electronics
Spare MAF sensor
Spare MAP sensor
Spare crank position sensor
Spare cam position sensor
Spare engine temp sender
Spare oil pressure warning light switch
Spare oil pressure gauge and sensor
Spare water temperature gauge
Water injection:
spare nozzles
inline filters
Spare solenoids
Spare pressure trigger switches
Spare power relay
Nitrous:
spare pills
nozzles
spare bottle
bottle heater
Tires and suspension:
tire pressure gauge
Tire thermometer
Tape measure for rollout measurements etc.
Consumables for the car
generic bearing grease
one case engine oil
Transmission Lube
Differential Lube
water wetter
brake fluid
brake pads
spray can starting fluid
Consumables for repairs
Trash and cleanup:
5 rolls paper towels
20 grease rags (red cloth)
box of trash bags (HD contractor clean up)
trash bag support frame for pits
Small broom
Foxtail brush and dust pan
Documentation / marking:
note pads yellow legal size
note pads pocket size
Mechanical pencils
magic markers ( sharpie)
Grease pencils
window white marker
In car video equipment
GPS unit with peak speed function
Car numbers
Sealants and special application supplies:
Gasket seal
aerosol can (copper coat)
permatex #2
silicone seal
hylomar
Honda bond/Fuji bond
Epoxy 5 min self measuring double tube style.
Hot melt glue
Hot melt glue gun
3M spray adhesive
WD-40
Permatex antiseize
Penetrating lubricants
liquid wrench
Locktite standard
Locktite stud and bearing
Locktite prep cleaner
Brake cleaner (non-chlorinated residue free)
1 qt acetone (for degreasing)
bottle windex
Fiberglass strapping tape
clear Poly tape
Thermal control testing kit:
probe Pyrometer
Infra-red thermometer
Electrical fabrication kit
electrical tape
liquid electrical tape
zip ties
shrink tubing
Wire crimp tool
crimp terminal kit
spare rolls of #12, #10, #14 #16 gauge wire
Ground straps
Electrical trouble shooting kit
Long #12 ga jumper with alligator clips
needle probe test light
Volt ohm meter
12 V test lamp with long leads
12v pizo buzzer continuity tester with long leads
Emergency fabrication supplies:
Pop rivets
pop rivet gun
battery powered electrical drill
Several sizes sheet metal screws (Pan head and hex head)
#6 x 1/2, #6 x 1, #10 x 1/2, #10 x 3/4, with appropriate drill bits
Assorted worm drive hose clamps
set of easy outs
sawsall w/ spare blades
diegrinder w/ abrasive cutoff wheels
4" right angle grinder w/ spare wheels
4" pad sanding disk (1/4 shaft)
assorted spare disks
small (threaded stud) sanding pads with mandrel (1/4 shaft)
small clearance right angle head drill rechargeable
Metal shears for sheet metal, straight, rt hand, lft hand
bolt cutters
Racers tape / duct tape
J B weld epoxy (3)
Black iron utility wire
safety wire (see safety wire kit)
Fiberglass patch kit:
Fiberglass cloth
Fiberglass mat
qt epoxy resin
Qt polyester resin
Can of body putty
special purpose tools
Engine diagnostic tools kit:
compression gauge
wide band O2 meter
lap top computer w/software
fuel pressure test equipment
hand vacuum pump kit
Vacuum gauge
Volt meter
OBDII scanner
Spark plug service kit:
spark plug gapping tool
spark plug magnifier
Spark plug socket with rubber grommet
hand drive disk
short extension
floppy head ratchet
shorty ratchet
Visual Inspection kit
magnifying glass
fiber optic bore scope
inspection mirror
Dropped part retrieval:
magnetic pickup tool
claw type pickup tool
Pressure switch testing and adjustment kit:
billet block to screw switch into
precision air pressure gauge
air pressure tank and regulator.
Engine assembly tools
Ring compressor
Torque wrench 3/8 and 1/2 drive
Torque angle gauge
Measuring tools:
Feeler gauges
0-1 micrometer
2-3" micrometer (main and rods)
3"- 4" micrometer (piston)
Telescoping gauges
0-6" vernier caliper
Tape measure
Wheel Alignment tools:
Tools to check camber / caster and Toe in
Plumb bob and masons twine
level
Toe in gauge
Battery service kit:
Battery post cleaning brush
small wire "tooth brush"
Battery post clamp puller (Claw foot clamp style)
Battery post clamp puller opposed jaw style
Specialty tools:
Hemostats
tweezers
O-ring and seal picks
Cotter pin puller (hose hook)
Spring hook (T handle)
Spring pliers
Special sized punches or bushings for installing removing bearings and seals etc.
Special lift, or installation hardware for engines or other heavy components (ie chain bridle cut to proper size for engine and balance points needed to comfortably handle engine)
Wrist pin remover
Large allen sockets to remove engine plugs (1/2 drive)
pry bars (bent end screw driver type, large, med, and small)
Gasket scraper
Putty knife
Tap and Die kit:
assorted taps and dies as needed for your equipment
Scotch bright pads
steel wool
wire brush (welders hand held)
wire brush (cup 1/4 inch shaft)
wire brush (standard 1/4 inch shaft)
Files and sharpening, Material removal:
File large single cut mill file
Large double cut
Med single cut mill file
Fine small single cut mill file
triangular file
Rat tail file Large
Rat tail file med
Rat tail file small
chain saw sharpening round file
Jewelers files
Sharpening stone (ceramic)
Sharpening stone (diamond matrix)
Hack saw handle
Carbide grit hack saw blades
trimetal blades (assorted)
One handed hacksaw blade holder
Carbide cutters for die grinder
Rubber sanding drums with abrasive sleeves (1/4 shaft)
It is just a starting point to be modified to meet your individual needs and equipment inventory.
Hope it helps!
Larry
jacksoni
And in the second tractor trailer you are going to put you and the race car! :-o :roll: :-D
Larry- are you going this year?
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
hotrod
#2
QuoteAnd in the second tractor trailer you are going to put you and the race car!
Ahhh -- yeah bringing the car is a good idea! I should add that to the list somewhere.
QuoteLarry- are you going this year?
I'm not sure to be honest. I am getting new rear wheel bearings installed on my drive to bonneville clunker tomorrow. They need a special press and tools to do it right so paying a shop to do it.  I might drive out for a couple days but will make that decision here in a week or so as some other things get sorted out. I just moved and lots of things are up in the air right now.
Larry
Just a small hint. Keep those eye drops in the cooler. REFRESHING!
Mac
And I though my load list was long...
Thanks for posting yours. It might stop me waking in the night dreaming of what I forgot to pack. Now I just have to figure out how to get it all there....
A couple of additions:
First Aid - burn cream and gel pads (sun burn and touching hot engines)
- Butterfly closures (for minorly deep cuts) - used them first myself when I learned engines were sharp suckers
Pit construction - 1 inch slats (cheap wood) - pre drilled to hold down edges of tarps in pit area screwed in with dry wall screws.
- Rough door mats to wipe salty feet on before entering pit area
And if we are really getting carried away... I would like a hand held vacuum to clean out the salt from under the driver's feet - in the car!
Many thanks for starting this.
Miriam
While we're on the subject of first aid -- Nancy and I carry a pretty-well stocked first aid kit in BOTH the trailer and the truck.  And the kits -- in plastic tackle boxes about a foot by 6" x 6" -- are very well marked so anybody can find them easily, and also they're packed right near a door -- so the responder doesn't have to dig for a half-hour to find it.  Last year we were helping with set up t SpeedWeek and on the very first day -- we'd only been on the salt for a half-hour or so -- one of the workers slipped and got a nasty abrasion on his shin.  Voila, we had the kit out and in use within a minute.
Pack your emergency supplies (including the fire extinguisher) in easy-to-access locations!
LSR Mike
here's an old list
The Land Speed email list land-speed@autox.team.net came up with a pretty good checklist started by Keith Turk and Jim Dincau. Successful teams run with one time and time again. It is very critical that one be used and implemented. SO here is one to start with and you can modify it accordingly to your vehicle and/or needs.
Check lists for an F/SR (mechanical injection, unblown, gas, short course)
For bigger faster cars add parachutes, alcohol, nitrous, nitro, attendant
paraphernalia and a much more comprehensive spare parts list
1. Engine prep
2. Car Prep
3. Trailer Prep
4. Trailer loading
5. Pits Set up
6. Pre-race
7. Starting line
8. Shut down
9. Between run Maintenance
Engine prep
1. Portable fire extinguisher standing by
2. Check valve lash
3. Check main Jet
4. Check barrel valve leakdown
5. Set timing
6. Install warm up plugs
7. Fill radiator and bleed head
8. Fill fuel tank and bleed lines
9. Fill oil tank and bleed lines
10. Pre-heat oil
11. Prime oil system
12. Start
a. Fuel on
b. Power on
c. Starter engaged
d. Open throttle
e. Oil pressure
f. Close throttle
g. Ignition on
h. Maintain 2,000 RPM
13. Check oil pressure
14. Check for fuel, oil and water leaks
15. Set idle RPM
16. Check throttle response
17. Warm up and shut down, use fuel shut off!
18. Check valve lash
19. Check head bolt torque
20. Check oil filter screen
21. Check barrel valve leakdown if linkage adjusted
at throttle response check and note new rate
22. If all is OK, sit down, lean back, relax, have a
drink and revel in the glory of just being
Car Prep
1. Drain fuel tank
2. Check wheel bearings
3. Check fluids
a. Rear end
b. Trans
c. Engine oil
d. Battery
e. Radiator
4. Clutch adjusted
5. Tire Pressures
6. Moon disks on
7. Fire extinguisher and harness cert OK
8. Blow out fire extinguisher lines
9. Fittings and fasteners tight
10. Charge battery
11. Injector stack plugs in
12. Power off
13. Do the brakes work at all?
Trailer Prep
1. Wheel bearings
2. Tire pressures
3. Grease ball and load levelers
4. Spare tire present and actually inflated
Pack Trailer/motor home
1. Drivers gear
2. Tools
3. CO2 bottle
4. Tune up parts
a. Spark plugs
b. Jets
c. QC gears
5. Fluids
a. Fuel
b. Oil
c. Water (empty barrel, fill before arriving at track)
b. Brake cleaner
d. Hand cleaner
6. Spare parts
a. An endless list moderated by paranoia, cash reserves and storage space (see 1st Post)
7. Shop towels
8. Floor jack and stands
9. Tow Strap
10. Battery charger
11. Weather station
12. CB radio
13. Portable fire extinguisher
14. Trash bags
15. Tarp and stakes
16. Canopy
17. Coolers
18. Chairs
19. Table
20. Umbrella that clamps to roll cage
21. And oh yes the car, and make sure its tied down right
Pit set up
1. Cooler in shade
2. Tarp
3. Canopy
4. Car out
5. Tie downs stored, otherwise they will walk away
6. Car prepped for tech
a. Drivers gear
b. Log book
c. Tow strap
d. Moon disks off
e. CB radio
f. Portable fire extinguisher
g. Dzus button tool & dust cover allen wrench
CAR PREP
1. Cooler still in shade
2. Tire Pressures
3. Lug nuts
4. Moon disks on
5. Fire bottle pin in
6. Fuel car
7. Check main Jet
8. Barrel valve leakdown
9. Timing
10. Warm up plugs
11. Pre-heat oil
12. Prime oil system
13. Injector stack plugs removed
14. Start and warm up, fire extinguisher standing by
15. Check oil pressure and idle RPM
16. Check for fuel, oil and water leaks
17. Check valve lash
18. Race plugs in
19. Injector stack plugs in
20. Gear ratio
21. Charge battery
22. Fill out race log page
23. Driver's gear, weather station, radio, fire extinguisher,
umbrella and small cooler with drinks in push truck
24. Cooler still in shade
Starting line
1. Injector stack plugs removed
2. Fire bottle safety pin removed
3. Reset tach
4. Driver prepared
a. Sufficiently hydrated?
b. Inhale deeply while starter tightens belts
5. Starting sequence
a. Fuel on
b. Power on
c. Starter engaged
d. Open throttle
e. Oil pressure
f. Close throttle
g. Ignition on
h. Check oil pressure and water temp
6. Check heart rate, if elevated you are ready to go
but wait for starters instructions anyway
SHUT DOWN Procedures
1. Calm down, you will be a lot cooler with the fire suit off
2. Pin fire bottle
3. Power off
4. Injector stack plugs in
5. Note data
a. Tach tell tale
b. Oil Temp
c. Water temp
d. Oil press out the back door
e. Barometer, relative humidity and air temp
BETWEEN RUN MAINTENANCE
2. Record data from run, try to get driver to be objective with comments
3. Fuel car, note consumption
4. Check spark plugs and piston tops
5. Check valve lash
6. Check oil filter screen
7. Check oil level
8. Charge battery
9. Check for loose, cracked, broken, bent or missing components
Hope this will help to get you started down the track safely.
Mike M.
BNI/ECTA
