APS forward vision rules?
Started by agjohn02, July 31, 2008, 11:04:09 PM
agjohn02
Hi all,
I have searched this forum extensively for the answer I'm looking for but cannot seem to find it.
I am in the process of designing a special construction, partially streamlined motorcycle and have a question regarding the required forward vision in this class. I see in the rulebook where it gives requirements for streamliner forward vision (7.H.7) but none for partial streamliners. How strict are "they" on front tires/neck/forks being in the line of sight? Are there any requirements for PS?
Thanks in advance and I'm sure I will have many more questions in the future as this is my first ground-up LSR motorcycle build. Great forum!
willieworld
#1
welcome--in the special construction class in A you have 2 choices --you have A which is special construction -and APS special construction partial streamlining--the streamliner S is a different class than A  ---just build to the special construction A rules --7.G--then add partial streamlineing --7.G.11--if you can take pics and post your build in the build diaries then if you have questions we can better understand what you are doing --if you havent already get a 08 rule book ---- good luck and hope to see your build --------------------willie buchta
it helps us to know what part of the country you live in also -------------------
willie-dpombatmir-buchta
Since it is a sit-on class, it is expected that you can see forward.  While there is no rule, before you invest a lot of time and money, you might want to submit a design to the motorcycle committee for a ruling.  You will need to be able to see where you are going, are you planning a periscope bike...  :-o
I've seen more than a few A/PS bikes where the rider looks through a relatively small windscreen mounted in the nose piece (but there's opaque 'class above the top of the window), and far more A/PS bikes where the rider looks over the top, or through a windscreen that is clear to the top edge.  I don't know of a specific "number of degrees of vision" that's required.  Perhaps that's because in many bikes the rider has the option of sitting up to take an obstructed look (I say that with tongue in cheek -- sitting up at 2 bills isn't necessarily the correct thing to do).
I'd agree with Stainless or Willie and ask that you consider posting a sketch or photo of what you've got in mind so we can try to help.  Also consider going to the SCTA website and posing your question there in the "rules questions" area.  You should get a definitive response that way.
Dean Los Angeles
QuoteSince it is a sit-on class
No, it is not.
The position that the 5050 streamliner that Nick Rock pilots head first, face down would be legal in Special Construction. There was a guy that ran a Suzuki years ago that ran that position.
Or lay down, feet first in the case of mine.
agjohn02
Thanks for the input. I was thinking something more along the lines of these two bikes. Where the neck and fork tubes are pretty much blocking vision directly forward of the bike in the full tucked position. Our rider last year had pretty limited vision forward when tucked and said he had no problems following the lines out of his peripherial vision.
