Safe Stopping Distance.
Started by stay`tee, August 01, 2008, 06:05:15 AM
stay`tee
Here in Australia the Queensland Timing Assocation is investigating a couple of airstrips to hold a landspeed event at.
Problem is, on average, these airstrips are just a little over a mile (1600meters) total length. One at 1640meters, the other at 1711.
If thay were to run a event over the kilometer, would 600meters be enough distance to stop a 200mph car or bike in :?
I realize that Maxton is a mile course, what distance dose it take to stop saftly there :?
RidgeRunner
      About .9 mile total shut down at Maxton with first turn off about .5 mile after finish/timing traps.  Many fast bikes [up to 250-60 range] use the first turn off regularly, it has a somewhat larger radius sweep than the very end of long shutdown.  Others use long shut down.
     Buddy with a 2400# roadster makes the first shutdown turn easily with chute and rear wheel brakes [GM] from 150, without the chute feels more comfortable using long shutdown and coasts a long way before he starts to brake when he takes that route.   Had no problems making first turn off with his 2900#  [larger motor] street roadster with front and rear brakes [GM] with out using the chute from 150.  Faster cars also use first turn off regularly.
     Pretty much all depends on speed, vehicle weight, aero, braking capabilities, and driver/rider comfort level.
     There are some links to videos [from both cars and bikes] of Maxton runs here on other threads.
      Good layout of the course from an air view on the ECTA-LSR.com website.
                                Ed Purinton
DahMurf
Also the Texas mile only has about a 1/2 mile shut down but it's wide & straight. Maxton has a slight right turn at the short shut down so it changes the dynamics slightly. Personally I think the short shut down is at slightly less then half way through shut down. Here's the overhead of our track:
Texas has had it's share of racers off of the end of the track. It happens when there are circumstances that make the shut down less the optimal.
Maxton has also had a few cars off the end when there have been brake or chute issues.
The shorter the shut down the more important brakes & chutes become and the less room you have for error. Also driver/rider shut down skills become more important.
More is better but the shorter can be done. I guess you really need to be looking at/considering what is at the end in the event someone does go long. Sooner or later someone will!
Deb
DahMurf
Ok, I forgot I've had this question before! Todd reminded me that the last time we were at maxton he measured the distance from the traps to short shut down on the GPS and it came out to .36 of a mile. So yes, the traps to short shut down is less then half of the full shut down.
Deb
Quote from: DahMurf on August 01, 2008, 10:39:28 AM
Deb
If I'm figuring right the .36 mile would be almost the same as the 600 meters.  Sounds like it wouldn't leave much room for error on a 200+ mph car unless it was running more of a drag chute vs. a lsr chute.  How long are the shutdowns at the tracks where the 200 mph drag bikes run?
Dean Los Angeles
You also have to ask what happens at the end? What is past the 600 meter mark? If the asphalt transitions to smooth dirt you might be able to have someone run off the end at a somewhat lower speed. If the end is a concrete barrier then you really can't risk it.
willieworld
--read debs post again ---.36 to short shutdown ---total shutdown almost 2 times that  or did i miss read it  willie buchta
willie-dpombatmir-buchta
Cajun Kid
I am not sure what the distance from finish line to the trunoff at short shutdown is.
But the entire shutdown is 4700 Feet,, that is just at .9 of a mile hard surface shutdown.
The Short shutdown is supposed to be .4 mile  but Todd D would know best if he used his GPS..
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Quote from: willieworld on August 01, 2008, 04:24:44 PM
Willie I'm stupid, what point are you making?
willieworld
none---hay is that a pipe bomb on your pocket or are you just happy to see me   willie buchta
Dean Los Angeles
Quote--read debs post again ---.36 to short shutdown ---total shutdown almost 2 times that  or did i miss read it  willie buchta
Since that was right after my post, I wasn't referring to here. The question was about an Aussie airstrip.
stay`tee
Thanks for the comments, thay are being read not just by me, but the people here in Oz that are trying to get this gig up and running. :-)
My understanding is that there is a grass run off area at the end of the bitumen, how long this run off? i dont know.
Most drag strips have a "minimun" braking distance of 1320 feet (400meters). I have noticed lately that the Nitro Harleys (heavier), since getting faster, are useing a lot more distance to stop.
As somewon posted, it really dose depend on vehicle, weight etc 8-)
1 fast evo 2
I have run at the Texas mile, and in a car with production brakes but good rotors and race pads you can stop ok at up to 180-190 mph but when you get over 200 mph you better have a suppercar or a good parachute (preferably both). I have seen quite a few cars and some bikes run off the end at Texas. At maxton the long shutdown is even longer than you need unless there is a problem.
I hope this helps a little.
      Mike Reichen
E.C.T.A. 200 MPH club
221.4 mph at Maxton sept. 08
stay`tee
I read on another thread that Texas has about a half mile shut down length. Half a mile = 800meters, ummm makes 600meters look very short :roll:, going to need a big anchor with a strong chain :-D
dwarner
LSR specific cars are generally lacking in the brake department. If the plans are to run the mix of vehicles like you see at Maxon and Texas the longest shutdown you can have the better.
