Post record flathead (four) question
Started by 4-barrel Mike, August 13, 2008, 09:02:26 AM
4-barrel Mike
Pardon my inexperience  :mrgreen: but:
Is this sufficient to seal a V4F after a (potential) record to allow further runs without a teardown?
The flash washes out the slot cut into the head stud.
More to follow.
TIA
MattS
I'd say no, because it looks like the nut & stud can be removed as a unit. Unless there is something preventing the stud from turning. I don't know if the stud is just threaded into the engine or has a head on the other side.
IMO
Matt
4-barrel Mike
Whew!  Long day, late night...
Two studs coming up!
Thanks.
RichFox
I took out one pan bolt that was drilled through. They put the seal in the hole. Couldn't remove the pan without breaking the seal.
4-barrel Mike
Thanks, Rich.  We thought of that, also, but as little as the two of us like crawling under that full-fendered A, we didn't think anyone else would like it either  :-D
It ended up looking like this:
Figured that if the power that be doesn't like the way it's wired, it could be redone under his direction.
jimmy six
If you set a record and during impounds you want to continue to run or be re-inspected for an additional class you will need to be sealed. The only thing you will need is the 2 holes you have drilled. The SCTA impounds rep or Dan will apply the seal using their wire and lead seal so it would be best to have the wire you have shown out of the holes. Don't lose the paper work given to you and remember to return to impound before you leave the meet to make the record official.
During your vehicle inspection for running a question maybe asked concerning a place to seal the engine as it is one of the slots on the back of the form. As an inspector I never asked if a place was provided and really didn't care. I felt that if a competitor felt they were going to set a record they would definately make the prepation such as you have done...Good Luck
